Start it?
#31
KMP for sure, Wright Motorsports is one of the dealers for them and I would guess they could send you the pdf if no one on here has it
https://www.wrightmotorsports.com/k-m-ppaddleshift
As for he dipstick the manual states the ball needs to be wetted but that is when the car is running and up to temp.
Since its been sitting I would drain all oil and see if there is any contamination from water or fuel to be safe.
The connector in the pass side I am not sure what thats for.
In our car we have that one too I think and some others.
Our car did have lighted numbers for the 25 hr so had extra wiring.
Last part the engine harness part that is a cover and should be able to kinda snap it back in place.
oh and the fuel cell should be 100 liter with probably 4 in tank scavenge pumps and 2 main pumps 1 primary and 1 reserve.
#32
also the guarded switch on the lower right I would guess is part of the paddles for the emergency bypass
on the Megaline we have and pic posted above from from dogger15 is for emergency.
it bypasses the ecu part of the shifter so you can shift with no protection from the system.
ie...if there is a problem with the system and it stops shifting you can force it with out the over rev protection
#33
Two additional observations: From the picture of your suspension, it appears that your car is sporting Cup S or Grand Am spec parts (former Orbit Racing?). The wishbone has the replaceable spindle bushing that Porsche issued a service bulletin on last month. Also, you mentioned being unable to locate premium ethanol free fuel in your area. If your car is equipped with an uprated engine (higher compression, more cam), you are going to need at least 100 RON fuel. Check for VP, Renegade, Sunoco, etc. race gas dealers. Even if your engine is stock, Porsche recommends a minimum of 98 RON. If you intend to self support, you can buy it by the drum (55gal), and have it delivered to your place or purchase at many tracks during supported events.
Finally, since the car has been sitting with unknown quality fuel in the cell for a while, I recommend you check the foam inside the cell. The shop that maintains my car does that as a matter of course and often finds that the foam breaks down and will clog the in tank pumps causing expensive problems.
#34
#35
#36
From reading one of your earlier posts it looks like you purchased the car in the fall of 2013.
I'd consider shipping the car to a shop that knows these cars and their systems and have them go through it before trying to run it. Also consider having someone out from that shop who can walk you through the process, even if it means buying them a round trip ticket.
https://rennlist.com/forums/porsche-...vs-2010-a.html
Regards,
Regards,
#37
Thanks guys. You are all being so helpful.
I also have a few practical event questions. The car does not have a passenger seat. I remember some events I went to in the past, where they would make you take an instructor with you until they signed you off. I have a couple very light carbon seats from the BMW days. You think they would let that fly?
The side windows have also been taken out in order to keep it cooler inside. Do they require netting at drivers schools or at club races?
I have a plastic neck brace for dirtbikes, that I never wear because I couldn't look down at the bike when riding, that will do sort of the same thing but not hook to the helmet, but I suppose I really should get a Hans device? [ I watched a few videos on a proper HANS and without some modifications this neck brace will likely not do the same thing. I'd delete the photo and remove the text but I can not see that option. ]
I can't fit into my old OMP driving suit, is one required or can I just wear cotton? Nomex underwear required with a suit? Maybe just in club racing?
I think I bought new belts for the car but I can't remember. I'll have to look at the tags. How old can they be? If I do need a passenger seat and new drivers belts, I wonder if I could get away with using the old bets for the passenger seat, since that might only be used for a few laps?
Thanks again.
Thanks again.
#38
Regards,
Regards,
#39
Euro RON vs US Octane
Since this was brought up I though you might be interested in the difference.
http://www.pencilgeek.org/2009/05/oc...nversions.html
