f/s 997 cup oem brake vents 400.00 or obo
Hello, I'm interested. Do you have a part number for the vents? And what goes in the slot next to the vent. I assume it's a lens of some sort. Do you have those or can they be ordered? Thanks in advance! Best Josh
The slot next to the vent is for a light that can be used as a running light or turn indicator if u are running on a street car.
The light they perfectly fits in there is a Jetta mk4 side marker.
The easiest way to adapt that to your factory plug is use a bulb socket adapter that has pig tails u can solder onto the Jetta positive and ground wire.
Attaching pics so you can see how I did it.
They do not work on the .1 car as the light opening is a different shape from the .2 car.
Mine are from Porsche motorsports and then I sent them to dBcarbon to do a much better carbon fiber finish on the exterior part of them.
