Fuel drain point for 996 cup
I want to drain the fuel from my 996 cup to change the fuel filter and wondering where the drain hose is installed into the fuel system? My thinking is it’s the plastic fitting with “CPC” etched into it. If this is correct, how do I remove the cap on the fitting? I can push it downwards but cannot actually remove the cap.
TIA.
TIA.
You don't need to drain the fuel to replace the filter, just undo the fittings slowly & release the pressure & replace the filter
Below is the fuel drain point just pull the black cap off & plug in the specific fuel drain hose then flick the fuel pump switch all the way up with the ignition on
^^^ Thanks James. There is was looking me right in the face the whole time. I was keen to have a go at using the drain hose but won’t bother if it’s not going to leak a whole
lot. Was mostly concerned about the hose with the plastic clip fitting.
Basic Sponsor
Yes, some do have it, but the Airlift is a really great alternative and it fits in the tool box to take to the track.
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
ed@demonspeed.com
https://www.amazon.com/UView-550000-...m+fill+coolant
Basic Sponsor
It works by pulling a vacuum on the system, then drawing the coolant into the motor eliminating any air pockets.
The ventrui vacuum runs on compressed air. A lot of it, so off of a compressor is better than nitrogen.
Ed
Ed
