Porsche Cup Cars
Air jacks leaking
Old 07-09-2018, 03:57 AM
spiller
spiller's Avatar
Default Air jacks leaking
Seems to be my week for starting threads. I just went to raise my 996 cup using the air jacks to swap wheels and there is a hissing sound coming from the front jack which gets louder as I allow more nitrogen into the system through the regulator. I cannot hear any leaks from the lines but when I put my hand under under the car in the vicinity of the jacking piston, I can feel air (not high pressure). If I remove the wand from the car, the car slowly drops the ground on its own before releasing the pressure, meaning the system is not holding pressure.
I last used it about a month ago and it worked perfectly. The car has since been to a shop for replacement of 80% of it’s cooling hoses and a center radiator.
Any ideas? I was under the impression that the jacking system was maintenance free.
Old 07-09-2018, 04:40 AM
Rickard 993 Turbo
Rickard 993 Turbo's Avatar
No no no
If you do it right they should be sent for service each year
Old 07-09-2018, 06:04 AM
spiller
spiller's Avatar
Originally Posted by Rickard 993 Turbo
No no no
I was only referencing what I read in the 996 cup technical manual.
Old 07-09-2018, 06:44 AM
Rickard 993 Turbo
Manual says
Old 07-09-2018, 07:35 AM
spiller
spiller's Avatar
Manual says
I’ll have to re-read the 996 manual as I don’t remember ever coming across that. Regardless, it appears I have an issue. What is involved in servicing them?
Old 07-09-2018, 10:32 AM
Rickard 993 Turbo
For me here in sweden i have sent
mine to krontec or sobek for service. Maybe you have someone in USA that service them
Old 07-09-2018, 01:01 PM
stujelly
stujelly's Avatar
cup car solutions here in the states is the one that can service air jacks.
I had the front air jack in our brand new cayman clubsport fail in the 6 hour we ran at sebring
No reason no warning, car had about 100 miles on it and probably 5 cycles.
Just bought a new one from porsche at the track and installed.
The old one will go to jack at cup car solutions for service
Old 07-09-2018, 01:39 PM
Viperbob1
Viperbob1's Avatar
http://cupcarsolutions.com/ Sometimes they can be rebuilt instead of buying new. On the 996s though you will find that water accumulates internally in the rear 2 shocks causing corrosion ( leaving air wand interface up and washing car or raining will also let water in. Plus just water from the compressed air). Many times these will need to be replaced due to this.
Old 07-09-2018, 11:12 PM
spiller
spiller's Avatar
Thanks for the info guys. I'll take a look at cup car solutions. They don't have an email listed on the webpage, are they on rennlist?
Old 07-10-2018, 01:39 PM
Viperbob1
Viperbob1's Avatar
No they aren't on Rennlist.
Old 07-10-2018, 04:24 PM
Ed@Demonspeed
Basic Sponsor
Ed@Demonspeed's Avatar
They are best reached by phone.
Ed
https://demonspeed.com/
Engineered Race and Track Products for your Porsche
https://www.goodaero.com/
Race Designed Aerodynamics
https://racingtirewarmers.com/
Win more races with tire warmers
Great products for racers by racers
ed@demonspeed.com
Demon Speed Motorsports is a proud sponsor of PCA and the Club Racing Program
Old 07-10-2018, 10:03 PM
stujelly
stujelly's Avatar
Ask for jack. No joke
If you need a new air jack, he can replace one cheaper than PMNA
Old 07-11-2018, 09:03 AM
AHRacing
AHRacing's Avatar
Back when we were racing them in Carrera Cup i had Derek Van Zelm remake the jacking piston for me. I am not sure where he is now. I would imagine that someone in Adelaide like K&A should be able to service or make a part to fix the problem.
Old 07-13-2018, 05:38 AM
spiller
spiller's Avatar
Thanks Andy. I found a Sobek dealer in NSW who said he can do it but didn’t even think of K&A. I’ll give them a call
Williamsf1 (04-24-2022)
Quick Reply: Air jacks leaking
