Engine idle speed 996 cup
The engine management will try to keep it around 1800 to 2000 rpm. It can only do this with timing and fuel as the is no ability to control the throttle. Alot of people have incorrectly adjusted the airbleed making the idle unstable or poor idle when cold. I have found that the best result are setting hot with the smallest amount of airbleed possible. This should give good cold start and little if any hunting at idle. If the setting is wrong you will get stalling and hunting at idle.
Laurence Gibbs (07-02-2022)
