Anyone here ever switch from 100mm to 120mm front springs??
Had a thought: if cup helpers are only 75mm free length and 652g a piece I suppose you could reclaim that additional mass from a longer main with a shorter helper. Do longer helpers assist in setting the ride height in any way? I imagine that if the helpers aren't coil bound at rest you are then messing with the transition point of the dual spring rate vs just the main rate.
