Basement Clean Out! 996 Cup Parts
All prices + shipping (i.e.: amount doesn’t include shipping)
Pictures available upon request PM or christiancook43 at yahoo dot com P/N, description, quantity, condition, price (excluding shipping), condition Engine 996.111.101.95 exhaust manifold left 1 SOLD Good 996.111.102.95 exhaust manifold right 1 SOLD Damaged, but repairable 996.375.011.94 Engine blade 2 SOLD Fair 1x red, 1x black, both warped 996.106.057.03 water tank (includes ventilation valve / pressure cap) 1 SOLD Good 996.106.131.51 radiator left 1 SOLD Good 996.106.132.51 radiator right 1 SOLD Good 996.606.128.00 O2 Sensor 2 SOLD for both Good Multiple Complete collection of coolant hoses & brackets SOLD Good Custom straight exhaust pipes, right and left (removes muffler) $200 New Walbro GSS307BX Fuel pump / pick up for fuel cell 2 $50 for both Good Electrical 996.603.019.90 generator 90 Ampere (Bosch Motorsports Alternator) 1 SOLD Good 996.604.107.00 Starter 1 SOLD Fair; teeth are worn at tip 996.602.104.00 ignition coil 6 $60 for all 6 Good Brakes 996.352.425.92 brake caliper left red 1 SOLDFair; cosmetically rough 996.352.426.92 brake caliper right red 1 SOLD Fair; cosmetically rough AP Racing Ft rotors w/ hats, 350mm floating 2 SOLD for pair Excellent, <6 hours AP Racing Ft rotors w/out hats, 350mm floating 2 SOLD for pair Good, some cracking AP Racing Rear rotors w/ hats, 330mm floating 2 SOLD for pair Good Transmission / Drivetrain 996.424.010.9A gearshift-lever bracket (shifter) 1 SOLD Fair; looks rough, OK tightness 996.424.040.75 control cable (shifter cables) 2 SOLD Good 996.423.229.92 rear throttle control cable 1 $100 Good 996.116.013.91 clutch disk 1 $50 Good thickness, can measure 996.116.027.75 pressure plate (Sachs P/N: 88-3082-999-752 ) 1 $300 New 996.116.237.90 clutch operating cylinder 1 $75 Good 950.116.813.30 guiding tube 1 $25 Good 950.116.086.06 release fork 1 $50 Good 944.116.080.01 release bearing 1 $25 Good Tilton 3-plate clutch disk + plates, 5.5" dia 1 $100 Good thickness, can measure Tilton Complete assembly, 3-plate, 5.5" dia (clutch plates, spacers, cage, flywheel, etc) SOLD Suspension 996.341.131.90 tensioning bolt ABS 48 tooth (axle) 2 SOLD Good 1x <6hrs, 1x hours unknown 996.341.121.90 wishbone outside front left (lower control arm, adjustable) 2 SOLD 996.341.122.90 wishbone outside front right (lower control arm, adjustable) 2 SOLD 996.331.241.04 rubber bearing (inner bushing for lower control arm) 2 SOLD New 996.331.121.90 wishbone outside left+right (lower control arm, non-adjustable) 3 SOLD 2x <6 hours, 1x unknown hours 996.331.121.90 wishbone outside left+right (lower control arm, non-adjustable) 1 $200 ~24 hours 996.331.112.06 upright right (right rear carrier, full assembly) 1 $750 New 996.332.024.23 articul. shaft (rear axle, black) 3 $100ea Used; unknown hours 996.331.671.90 central bolt (stub axle) 8 $100 for set of 4 Used; unknown hours; 1 set PMNA, 1 set Demon Speed 964.361.113.70 pressure disk for BBS rim 8 $100 for set of 4 Used Body 996.512.991.9B Rear cover without wing (decklid) w/ gurney flap 1 SOLD Repaired damage underneath 996.512.992.90 rear wing 1 $1,000 Carbon; Crawford mfg 996.512.981.92 wing support left 1 SOLD Good 996.512.982.92 wing support right 1 SOLD Good 996.631.485.00 tail lamp left 1 SOLD Fair, minor damage on bottom 996.631.486.00 tail lamp right 1 $25 Used, major damaged to lens Interior 993.347.084.70 steering wheel + hub 1 SOLD Fair; hub assy new Wheels 996.362.207.90 front outside-ring 1,0x18 (BBS wheel half) 2 SOLD Good 996.362.209.90 rear outside-ring 1,5x18 (BBS wheel half) 2 SOLD Good 996.362.203.91 front inner-ring 7.5x18 (BBS wheel half) 2 $100ea Good 996.362.205.91 rear inner-ring 9,5x18 (BBS wheel half) 2 SOLD Good 996.362.221.90 sealing ring (metal ring + seal) 3 $25ea Good BBS 0229021 wheel center, early style 2 $150ea Fair; Cosmetically rough; some rub marks on inside BBS 0229052 wheel center, late style 1 SOLD Poor; Inside face milled 1mm and rough from broke axle; used with spacer BBS 0228152 wheel center, RSR, magnesium 1 SOLD Good, but could use refinish Race Parts Jack stands, single level (capital city motorsports) set SOLD Good |
Pic of the steering wheel request:
https://cimg0.ibsrv.net/gimg/rennlis...c81e342bcd.jpg https://cimg1.ibsrv.net/gimg/rennlis...8573fdaaba.jpg https://cimg2.ibsrv.net/gimg/rennlis...ff51262237.jpg https://cimg4.ibsrv.net/gimg/rennlis...8d9d72443d.jpg https://cimg3.ibsrv.net/gimg/rennlis...5b6480943b.jpg |
PM sent
Got a request for a pic of the straight pipes. Here ya go...
https://cimg8.ibsrv.net/gimg/rennlis...d9b057f5eb.jpg https://cimg9.ibsrv.net/gimg/rennlis...5415d68651.jpg https://cimg1.ibsrv.net/gimg/rennlis...1075f21263.jpg https://cimg1.ibsrv.net/gimg/rennlis...e1c801b2bf.jpg |
PM sent.
Got a request for pics of the uprights and the wing. Note the wing has a scratch on the top which needs / can be buffed out. It's a Crawford wing and will be sold with black side plates (yellow and the picture) and without the gurney flap (show in the picture).
https://cimg3.ibsrv.net/gimg/rennlis...e62eebef45.jpg https://cimg4.ibsrv.net/gimg/rennlis...6b811eb2bb.jpg https://cimg5.ibsrv.net/gimg/rennlis...c20fac3e59.jpg https://cimg6.ibsrv.net/gimg/rennlis...c1f565eb61.jpg https://cimg7.ibsrv.net/gimg/rennlis...01e4825d86.jpg |
All PM's & e-mails responded.
Here's pics of the jack stands.
https://cimg1.ibsrv.net/gimg/rennlis...623aa133f7.jpg https://cimg3.ibsrv.net/gimg/rennlis...2c870f49cc.jpg https://cimg4.ibsrv.net/gimg/rennlis...05eee51c38.jpg |
Do you have pics of the decklid and the repaired damage? I'd be interested in the decklid, wing, and uprights.
Here's some pics of the decklid. Shoot me a PM or email and we can work out a deal for all. I've got interested in the uprights, but no deal is yet done on those.
https://cimg7.ibsrv.net/gimg/rennlis...4ef857cde7.jpg https://cimg9.ibsrv.net/gimg/rennlis...29caba61ba.jpg https://cimg8.ibsrv.net/gimg/rennlis...c1baa4aa43.jpg https://cimg2.ibsrv.net/gimg/rennlis...56623e1447.jpg https://cimg6.ibsrv.net/gimg/rennlis...be58b8fead.jpg |
could you please post pictures of the rotors? Are they the current offering form Essex or the older wrightwood design?
Thanks, |
Sent PM on the bbs wheel center for $50. Can you please get me a pic of it. I think it may work for a piece of garage art I'm making.
Lots of pings on the LCAs. Below are pics.
https://cimg3.ibsrv.net/gimg/rennlis...724f8df735.jpg https://cimg4.ibsrv.net/gimg/rennlis...83e6c9c2c5.jpg https://cimg9.ibsrv.net/gimg/rennlis...762cdfb61b.jpg https://cimg0.ibsrv.net/gimg/rennlis...a34e53f60a.jpg https://cimg2.ibsrv.net/gimg/rennlis...2dcfe33dc7.jpg https://cimg1.ibsrv.net/gimg/rennlis...1b1336f359.jpg |
Updated and all PMs answered.
