spring rates
spring rates
hey guys,
I have a 996 cup with all rsr suspension parts and JRZ 3 way suspension. I broke down the suspension last night to send out for rebuild and found I had #750 front and #1500 rear. to me that seems a little soft in front and heaving in the rear. car weights around #2,700 the car feels great on the track, but I'm thinking I might be leaving something on the table with the current setup. my home track was just repaved and very smooth.
Any insight to what others are running in regards to spring rate?
thanks
thanks
Basic Site Sponsor
Basic Site Sponsor
These are Cup's original springs. Multiply N/mm with 5,709 and you'll get lbs/in.
996 Cup '05
F:
Spring 100/240/60 (240 N/mm = 1370 lb/in)
Helper spring 75/60/43
R:
Spring 130/260/60 (260 N/mm = 1484 lb/in)
Helper spring 60/60/50
997 Cup ('06-'07):
Fmain length mm - N/mm: 100-260 997.343.531.90
Ftender length mm - N/mm : 75–43 996.343.537.90
Rmain length mm - N/mm: 130-260 996.333.531.90
Rtender length mm - N/mm: 60-50 996.333.537.90
997 Cup ('10):
Ftender length mm - N/mm : 75–60-43 996.343.537.90
Rtender length mm - N/mm: 80-60-60 997.333.537.90
996 Cup '05
F:
R:
997 Cup ('06-'07):
997 Cup ('10):
Pete
Power. Lots is good, more is better, too much is just right...
'87 951, RIP
'00 996 C2 L92U AQ / IXAA IXRB IX54 M96/7.xx G96/7.88 M030 M375 M376 M436 M476 M601 M983 ... + 991 GT3 brakes, 997 GT3 sway bars, fully monoball'd suspension, Bilstein Cup Car coilovers, do88 Big Pack ICs. 10 & 12 x 19" BBS CH-R wheels with 265/30 & 325 /30 -19 MPSC2s.
Pete
'87 951, RIP
Try 1000 or 1200 up front and adjust handling via the dampers
On a 996 Cup up want the Rear springs about 10% greater rate than the fronts, If RSR bodywork you want to run same front and rear like 997s as a place to start
