BBS Wheel Help
BBS Wheel Help
Wanted to see if anyone could help me with what the offsets of these wheels are. Considering them for my track wheels.
BBS E88
These are 18 inch and are race wheels which do not have offset markings.
The front wheels have a 7 inch back spacing and the rears have a 8.5 inch back spacing
They will accommodate virtually any size brake caliper
Front's are 10 inch wide and rears are 12 inch wide. The car was a 997.1 version (narrow body)
They can be mounted center lock or 5 bolt
The wheel centers are: 522 0288170
BBS E88
From online calculators, Im getting
Front: 38.10
Rear: 50.8
However, I have also found this:
In 2010 the Grand Am Porsches ran 0288170 centers all around (up to 2014) with 2.0 / 8.0 front for ET +31 and 2.5 rear for ET +43.5. In 2012 they went to a 2.5 outer on the front and a 3.0 outer on the rear. Some teams ran other rear combos like 3.5 / 9.0 but the 3.0 / 9.5 was most popular. This just widened to the outside all the way around for offsets of +24.5 front and +37 rear.
So thats why Im confused as the front ET of +31 is a lot different then the calculated ET38 , rears are also different by 7mm too
Front: 38.10
Rear: 50.8
Tye,
There is a set of Grand Am spec 10, 12x18 BBS on eBay that came off a 997.1 NB. The seller is asking $3250 and he says he will build them to any spec you want. They look nice. I don't know the seller but I thought I'd pass it along. JBO
Originally Posted by gt2-josh
Tye,
Got it. I didn't know the dude on ebay is the same guy selling the set on the board. I thought the eBay seller may be able to build them to your spec. Josh
Now I got it. Either way it's a good deal especially for getting an ideal setup to fit your Cup fenders. I just bought an ex Mooty set in perfect condition and paid a premium for the Mooty provenance LOL!!! JBO
Post up the width of the inner and outer barrels and I can tell you exactly what offset they are based on 170 centers.
Thank you. I have requested the wheel half sizes twice now but haven't got a response yet. The wheels centers are all 522 0288170
I will do the best I can to help here.
As I listed in the ad the wheels are 10" wide with 7" back space front
and 12' wide with 8.5 inch back space rear.
The wheel halves are 2" outer and 8" inner front
and 2.5" outer and 9.5" inner rears
Here is where some of the confusion may be arising from.
The actual measurements on the 10 inch rims when measured from outside to outside on the rim is 11" given that the tire bead is a 1/2" in on both sides they are 10's ...same ratios on the rear
I only have ever had race wheels built by BBS (and Forgeline) and honestly have never dealt with ET measurements
I'm sure there is someone more experienced than me that may be able to calculate the ET
Bumping this thread as I'm interested in 0288170 centers. Does anyone happen to have the following spreadsheet as pictured below only for 0288170 centers that they would be willing to share? A jpeg will suffice as well.
Thanks in advance.
Thanks in advance.
