First time in Cayman R on track
SCCA Chicago Region, June 9th:
Driving into the sunset on the last straight was very serene. This was my first time on the track in the Cayman R, so I spent most of the time getting to know its general handling characteristics and feedback from various actions/inputs. Incredibly neutral car and very communicative. And bejeezus the new Michelin PS4s are very impressive for a street tire with a 300 treadwear rating on track.
This 3rd session I was the most comfortable and felt like I could grab it by the scruff at times since my tires were dialed in (PSI + temps) and I was confident in the brakes. In the first 2 sessions I was mostly in 3rd and 4th gear, but here in the clip I'm down in 2nd on some tighter turns for faster acceleration to the straights.
Current setup:
OEM Short shifter
OEM GT3 brake ducts
OEM R pads F&R
Motul 600 fluid
Michelin Pilot Sport 4S
Stock alignment
Anyone else run their Cayman R on track fairly stock? I believe there's a good amount of time to shave off with this setup as I was fairly conservative (in comparison to this guy who appears to be at 9 to 10/10ths):
Cheers!
Current setup:
OEM Short shifter
OEM GT3 brake ducts
OEM R pads F&R
Motul 600 fluid
Stock alignment
Cheers!
Just hit Road Atlanta over the past weekend for my first time at the track with my R. Car is largely stock, including crappy RE50s, except Fabspeed headers & exhaust.
I swapped out the brake pads for Pagid Yellow front / Black rear, and Castrol SRF brake fluid. I had a bad experience with brake failures in a different car and didn't want a repeat.
Echo your comments on the car being neutral and communicative - the steering feel is pretty incredible. I had to cut short my last session as coolant temps climbed over 220...time for a third radiator!
My R is mostly stock and love the car for track. Was just at road america this week.
I also swapped to pagid yellow pads for track - the stick pads stop well but i found them very hard on rotors wearing them quickly so when i replaced rotors i also switched to pagid pads. The pagids are much gentler and i prefer the feel.
I also noticed a big improvement with the adjustable front control arms to enable a more track oriented alignment.
I didnt like the long brake pedal action so swithed to a gt3 master cylinder which wasnt too bad a DIY job.
Great cars.
Great cars.
