987 Cayman with PCCB Winter Wheels/Tires
I have an 06 Cayman S with PCCBs and I am trying to figure out how to go about putting winter tires on it. I have done a few searches with no real results as to a viable solution.
Is anyone else in a similar situation where they have 19" wheels and PCCBs and need winter tires? If so, what do you do for wheels and what tires do you get? It looks like there aren't any winter tires available on Tire Rack that fit the standard 19" rims...
I have no problem changing to a smaller wheel size (18") but I don't know that 18s would fit over the PCCBs.
Probably best to get the 18" wheel/tire package as smaller (read narrower) tires are better in the snow.
You could get the 19" tires but you'd have to have the summer tires removed and the winter tires installed and summer/high performance tires don't "like" to be removed/installed.
Anyhow, here's a link you might find of some value.
https://www.tirerack.com/snow/Winter...Standard+Model
Apparently TireRack offers both 18" and 19" wheel and tire packages for your car.
Has anyone put 18" wheels on a Cayman with PCCBs? If so, what size/offset? This would probably be the best option if it is possible.
