Navigation issues
Navigation issues
Greetings folks,
My 06 Cayman S is having some factory nav issues. It doesn't know where I am. I have checked the antenna connection under the cowl, did the 148 reset and pulled the fuse. It is still showing zero satellites. Everything else in the pcm works just fine. What else can I check?
I had a similar issue, although my car is a 2016. The nav showed me like 20 miles away from where I really was. It was very strange. I tried resetting and pulling the fuse, no help.
We checked the antenna, and that was fine, so dealer needed to replace the entire PCM module. Hope that is not the case for you, but that was my experience.
