Bad oil change = Cayman Engine Seizure?
#31
House is great, thanks for asking. The plugs were pulled out and they look fine, exactly 8 quarts of oil in the car, and correct oil filters. Even with the oil out it will not hand crank so something is stuck. There are no metal fragments in the oil that they drained so there may not be broken parts in the engine itself. Im thinking that a valve may have gotten stuck up or something dumb like that but won't know until I remove the engine and tear it apart. They seem baffled by this whole thing and I don't know what else to do. Any ideas?
#32
There may not be anything even in the oil filter housing/oil either for the same reason. The engine didn't run long enough.
Besides a simple drain may not have any bits flow out anyhow. The pan should be removed. Then the metal fragments might be present. (The presence of metal bits though while in this case probably is bad news this is not the case in, well, all cases.)
I seriously doubt the tranny has anything do to with the engine not turning but it does have to come out to get the engine out so all is not lost.
If the tech can't turn the engine over by hand with the plugs removed there's something busted inside the engine.
A cam chain has let go and open valves are preventing the pistons from moving. That the engine can't be turned in either direction -- i guess this has been tried -- suggests both banks have non-moving valves which points to an IMS chain.
Congrats on the house. It is ok the Porsche doesn't run but the lawnmower had better be in top shape! Can't have the new house's lawn looking all rough now can we?
#34
If the engine stops running right away there may not be any fragments of metal in the oil. The engine didn't run long enough for any thing to make it to the pan.
The Cayman I had in the shop, it was immediately obvious when I pulled the cam covers what had happened.
#35
Any way it could be just a bent rod? The wouldn't be the worst thing that could have happened as long as it didn't destroy anything else. If it is the IMS then I have heard a lot of complaints on this issue so why hasn't PO stepped up to fix this?
#36
If it was a valve or the IMS then the engine would not turn at all I would think. It goes 30 degrees in either direction. If it was a valve wouldnt it go 30 degrees one way and 330 degrees the other way and get stuck?
#38
No. The non-moving valves -- remember if IMS chain failure neither intake or exhaust valves are opening/closing -- limit the engine to not many degrees of movement. 30 degrees in either direction sounds about right.
You can wish for a broken rod if you want. If you think that's better somehow then I hope you get your wish. And I hope you are right.
Right now no one can say. Someone's going to have to get their hands dirty and open up the engine enough to either confirm the valve train is causing the engine to lock up (ignoring the tiny amount of rotation you can eke out of the engine) or it is something else (a rod?) deeper in the engine.
#39
So had to do an engine replacement on the car at a cost of $12,000 for a used engine. The dealership will not tell me what went wrong with my original engine so it looks like we will never know what really happened.
#40
#42
Received 5,388 Likes
A dealership won't know what went "boom". They won't spend the money to do the autopsy. They just want to plug in a new motor.
#43
Late Porkchops
I am not sure I am following this right.
With the car at the Porsche dealer they wouldnt , or didnt , pull the covers to get an idea of what the most likely problem(s) was as Mac had suggested above.
Then they sold you a used engine .
I hope it all came out well for you, but I dont like the sound of the steps to get to the cure here .
#44
They do the same with their race engines that cost $60K? They don't want you to touch them or make any modifications to the internals. One heads of the teams in the LeMans series was telling us that basically Porsche is a one way street with information about their engines. If I had to pay $12k for a used engine, I'd be pissed if they weren't going to tell me what went wrong. Once they weren't going to help out on the cost of the replacement, I would have taken it to a local Porsche shop with build experience. The extra $4k-$6k more for a rebuild with improved rods and crank would have been worth it.
#45
