Exhaust
Exhaust
My Cayman R does not have Porsche Sport Exhaust. I want to upgrade stock exhaust for better performance and sound, without losing cats (emissions inspectors look under car for them). Any recommendations? Has anyone bought the pieces to substitue Porsche Sport Exhaust for stock?
REMUS is really one of the most popular options for these cars as it remains civil but gives that exotic wail the Cayman deserves. We have it in stock as well.
It does delete the secondary cats, but that does not throw a CEL, and you retain the primary cats. Unless they compare OEM schematics versus your aftermarket exhaust, you will pass sniff tests. Secondary cats are there for cold start up emission controls.
I have Fabspeed street exhaust on mine. Very civil when you want it to be and screams when you get in it. Very high quality workmanship. I would certainly buy them again if needed to.
Do any of you have experience with your aftermarket exhaust at Laguna Seca? Were you compliant? What db's do you hit? We have a track here in Phoenix with similar sound limits, and I intend to run LS again.
Orthojoe has the Remus on his Spyder and says it passed at Laguna Seca. If you have a Cayman R you really need to check both forums (this and the 987 one) - I'm in the same boat.
https://rennlist.com/forums/showthre...ferrerid=68981
I run an APR exhaust at Lime Rock where the sound limit is ~88db. No problems with being too loud. I know other caymans run there with different cat backs as well, no issues that I'm aware of.
GelbGT3,
I hope my comment, "If you have a Cayman R you really need to check both forums (this and the 987 one) - I'm in the same boat" came across the way I intended it.
My point is that there is a lot of cross-over in the 987 forum that you'd probably want to see, not an admonition to search all forums. I posted just before leaving work and thought better of it on the drive home. I'm sorry, if I came across poorly.
The best sound I have heard on a Cayman is the Capristo system: full headers, sport cats, and mufflers. The system has valve control, so you get two tones, street and track.
I have heard many Cayman through the years and this system is just Art, I liked it so much that I got it for my 2007 Cayman S.
Capristo is made in Germany, they fabricate systems for Lamborghini, Ferrari and other high end cars. Best quality and great sound.
They also make just mufflers, but their headers/sport cats combined with the muffler provide a gain of 25Hp, so the Cayman R gets in the 355Hp territory.
I did not dyno my Cayman, but I noticed the gains on the new system right away. It feels like more than a 25Hp gain, and it gained a lot beyond 6,500 rpm rather than going flat at that range.
The secondary cats are deleted, but the car doesn't throw a CEL, despite being on Sport Cats.
The best part is resale value, when upgrading the car, go back to the stock exhaust and get good money for the used Capristo system.
Thinking outside da' bun...
Very happy with my Remus. To me it sounds the most "exotic" of all the aftermarket ones, but very livable if you want to just poke around. I will say I have gotten some intermittent CELs since I swapped it in, but the dealership confirmed its the O2 sensor/exhaust throwing them. So I just ignore it for now when it shows up.
Fit and finish is spectacular. Thought about the Capristo, but couldnt talk myself into the price so I wussed out. I may get some headers eventually which may then put me in the ballpark of what a Capristo woulda cost, but I think I might still come in under budget. At the time I couldnt get the Capristo with black tips and that was a dealbreaker.
