hard to start...need help!!
Old 07-20-2011, 10:36 AM
soan
7th Gear
soan's Avatar
Default hard to start...need help!!
HARD TO START FOR FEW SECOND !!
FAULT CODE - P1023, Fuel high pressure too low during starting.
- P1026, Fuel high pressure implausible.
need to check which part, izit fuel pump problem? or......
Old 07-20-2011, 07:14 PM
KS-CS
KS-CS's Avatar
Is it a generation 2? Sounds like the fuel pump . . . did you see this thread:
https://rennlist.com/forums/porsche-...mp-recall.html ?
Old 07-21-2011, 12:37 PM
soan
7th Gear
soan's Avatar
i had change the fuel pump and regulator but problem still existed. how bout high pressure pump?
GlenC (02-13-2022)
Old 06-28-2012, 08:53 PM
kylevestermark
kylevestermark's Avatar
Default P1023 problems
I had the dealer confirm the P1023 code and they stated the high pressure fuel pump needed to be replaced. I am taking it to my independent porsche guy to change the pump. Does anyone have any other information on this issue?
Old 05-18-2017, 12:35 AM
Felipecr2017
2nd Gear
Felipecr2017's Avatar
Hi, ihave the same problem Cayenne 09 with code 1026 and 1023.. i already changed the Fuel Pump and sensor but i have the same problem hard to star and no rev over 3000 rpm... what else i can check??? HELP !!!!!!!
Old 05-26-2017, 01:08 AM
altonj
altonj's Avatar
Which pump got replaced?
Old 05-26-2017, 11:55 PM
Felipecr2017
2nd Gear
High pressure fuel pump..
Old 06-25-2017, 06:18 PM
PorscheBelgium
PorscheBelgium's Avatar
Hello,
I have the same error, p1023, piwis says:fuel high pressure too low during starting upper limit value exceeded porsche.
When i try to start the car after a day of not using it takes like 10 seconds before it starts and it also has a rough idle until i hit the throttle a little bit. I read a lot about a faulty high fuel pressure pump. But i don't want to spent over 1000 euros (or dollars) if it won't fix my problem.
What did you do eventually?
Kind regards from Belgium
Old 06-28-2017, 11:32 AM
PorscheBelgium
What was the issue eventually?
Old 07-09-2017, 12:39 PM
PorscheBelgium
Hi, what solved the issue for you? I have the same issue but a new high pressure fuel pump costs me over 1000 dollar. So i want to be sure i replace the right parts.
Old 07-12-2017, 04:24 AM
PorscheBelgium
Did you ever solved the issue?
Old 08-06-2017, 03:21 PM
hubbard316
hubbard316's Avatar
Did anyone ever solve this issue? I'm having the same problems and symptoms with. 970 Panamera S. any help would be appreciated. I have already changed the HPFP, Low pressure in tank pump, high pressure sensor as well. Still getting the same issue.
Old 04-14-2018, 02:17 AM
Legitlooks
Legitlooks's Avatar
Anyone find the answer for this? Same problem on my 2014 panamera v6. Replaced hpfp. Fuel pressure sensor. And low pressure in tank pump. Any ideas?
Old 11-03-2019, 07:03 PM
gumpo
4th Gear
gumpo's Avatar
Any updates on this please?
Old 01-31-2022, 03:20 PM
Szym10
2nd Gear
Szym10's Avatar
Hi, you solve the problem, I have this same in panamera s 970.
Quick Reply: hard to start...need help!!
