What do I need to know before buying a used Cayman S?
Old 02-09-2011, 06:43 PM
pedsurg
pedsurg's Avatar
Default used croc
Could you elaborate on the dfi issues to which you refer ??
Although you'll not get a dfi for 30 K, as the owner of an 08 and then 09 (dfi) croc, I'd be wary of longterm ownership of any intermediated shafted waterpumper.
Jack
Old 02-10-2011, 06:00 PM
mikefocke
mikefocke's Avatar
One weakness of the M96 engine is the Intermediate Shaft Bearing (IMS) and there is the ability in a 2006 to replace the factory unit with a third party (LN) unit (generally done at clutch replacement time) on an '06 where the '07-'08 engines require the disassembly of the crankcase in order to replace the bearing due to a design change. The difference in cost is thousands of labor dollars.
Old 02-10-2011, 07:01 PM
TAch Miami
TAch Miami's Avatar
Most Caymans have the M97 engine with no IMS problems. The 05's and some early 06's would probably have a M96. Beside the dealer, a Durametric can retrieve the engine specs.
Quick Reply: What do I need to know before buying a used Cayman S?
