Would you replace this RMS?
Old 02-15-2019, 10:38 AM
tominboise
tominboise's Avatar
Default Would you replace this RMS?
2006 Cayman S, manual transmission, 62k miles, autox and hill climb car.
I have the transmission out of the car to do a clutch replacement. The RMS has a lot of grunge around it but not really leaking per se. Would you replace this proactively or leave it?
Old 02-15-2019, 12:04 PM
jscott82
jscott82's Avatar
It's so cheap and easy, replace it every time you have the opritunity.
Old 02-16-2019, 08:31 PM
KevinGross
KevinGross's Avatar
Agreed!
Old 02-19-2019, 01:59 PM
Anthonyr105
Anthonyr105's Avatar
When my shop did mine they said if they aren't leaking at this point they don't touch it. Mine had a slight leak when the clutch was done so it was replaced. Now I have the tiniest drip on my trans with the new seal.
Good luck!
Old 02-19-2019, 02:12 PM
tominboise
tominboise's Avatar
Thanks for all the replies. I have cleaned the area and will replace the RMS. I don't plan on opening up the IMS at this point, as it is dry on the outside.
Old 02-19-2019, 02:18 PM
Anthonyr105
Good call. To remove the IMS seal you need to lock the cams or bad things can happen
Old 03-01-2019, 09:59 AM
tominboise
tominboise's Avatar
I completed the RMS replacement, along with the new AASCO flywheel and Sachs clutch and pressure plate. Car is back together and so far seems to work beautifully. Some additional gear noise in the car at times, but the clutch feel is way lighter and the car seems to be quicker on acceleration - I have just taken one short test drive to make sure all was well and nothing fell off.
Quick Reply: Would you replace this RMS?
