Air filters
Air filters
What do all of you think about the afe dry air filters and are they worth $210 each ?
these are for a Cayman s 2015 or should I stick with Porsche filters ? (At $34.00 each).
All aftermarket air filters are basically just sound enhancers, i.e. louder air intake sound . Any performance improvement (usually 4-5 hp) can only be measured on a dyno or an extremely fine tuned butt. However, if you package with other performance equipment, they may enhance performance somewhat.
I've used both afe and K&N oiled filers on BMWs but have found it too difficult to access on Porsches. So, the enhanced intake sound isn't worth the effort IMHO.
James Bond smoke machine
I have the K&N as it was in the car when I bought it. While driving through a small rain I noticed a large white cloud trailing behind me. I was freaking out that my engine blew. I called the guy I bought it from and he said that happened if you drove in the rain. Now I was worried about a vapor lock as moisture was going into the engine. Needless to say I have never driven in the rain again and I’m switching back to stock. As for the cloud, it was intense and I could not see anything behind me. It was cool for a moment and then I sweated bullets thinking the motor was dying.
I run K&N and have been happy. No significant performance increase but as noted in earlier Reply, it does alter the exhaust sound; making it (IMO) a more pleasing "throatier" sound. I haven't added a full-on aftermarket exhaust... but did find a steal on a set of Fabspeed tips that have a neat X pipe connector that helps (a little bit) with exhaust flow... and these two mods together give me what I want. A calm idle exhaust note... but when I stomp on the skinny pedal, the sound is very pleasing (to my ears...).
Something to keep in mind if you're a DIY. On a 981 (and probably other Gen), getting to the filters isn't a 10 minute task. I'd guess with proper panel tools, figure about 20-30 minutes to carefully pull off all the necessary trunk panels etc. to remove the filters for cleaning and charging. And... if you aren't setup to accelerate the drying of the new (recharge) oil (and don't oversoak!), you'll be off-line until the new oil is dry and you reinstall. I kept my OEM filters (which were in good shape; clean) for any situation where I'm doing the maintenance and want to drive before the oil dries 100%. Search the Internet for blogs/stories/tips on what happens if you don't wait for any oil-based air filter to fully dry.
Basic Sponsor
If you're looking for exhaust mods that will give you more noticeable power, I would suggest our Sport Headers with 200Cel HJS Cats. Guaranteed no CEL.
Cheers, John
Jim
OLY-S (03-12-2021)
