981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Need help running cables for Blackvue dash cam
Old 09-22-2018, 11:51 PM
shivaprf14
shivaprf14's Avatar
Default Need help running cables for Blackvue dash cam
Hello everyone, I have been trying to find videos, documents, pictures for the past week trying to find out how to run the cables in Cayman S 981 (2014) for the Blackvue dash cams, both front and rear cameras. Any help is greatly appreciated.
Not a great picture, not sure why the purple outline is showing.
Old 09-30-2018, 01:18 PM
GiuseppeM
GiuseppeM's Avatar
How are you planning to wire it? Hardwired to fuse box or lighter plug?
It’s fairly simple, center the camera right under the mirror, pop the mirror plastic housing just enough to run both power and rear camera wire, run above and to the A pillar, you can either push the cables in with a plastic auto trim removing tool or pull it just enough to easily push the cables.
Then run one wire to the fuse box or lighter plug and the other to the rear glass. You’ll have to lift the rubber gasket above the door to fit the wire.
If you use the fuse box you’re gonna need a “add a fuse” and tap into a fuse that is only on when ignition is on.
Quick Reply: Need help running cables for Blackvue dash cam
