981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
981 fluids and cooling <= a couple of quick/easy questions
Old 04-20-2018, 02:33 PM
GryGst
GryGst's Avatar
Question 981 fluids and cooling <= a couple of quick/easy questions
Apologies if this is topic has already been addressed elsewhere on the forum. I did search, but didn't have much success...
I'd like to better understand how fluids are cooled in my 981 GTS with a 6-speed manual trans-axle. In the nose of my car, I've got three heat-exchangers. My understanding is all three are for coolant. The car has two side-intakes. At least one of them must be an air intake for the motor. But I don't have a clue if/how/where (i) engine oil and (ii) trans-axle fluid are cooled. I've also read that the gauges may be calibrated in such a way that what's reported to the driver may not represent what the sensors are actually seeing...
Questions:
1. Can someone offer up a quick primer on the fluid cooling systems -- or point out a thread that does so?
2. Where is the heat exchanger for the AC?
3. Is the engine oil cooled? If so, how/where?
4. Is the trans-axle fluid cooled? If so, how/where?
5. What coolant and oil temperatures are folks seeing on track -- and at what point are the temperatures high enough to merit truncating the session?
6. Has anyone replaced their trans-axle fluid and had it tested to see if its been degraded prematurely by high temperatures?
Thanks for your help.
Kindest,
GryGst
Old 05-03-2018, 01:15 PM
GryGst
GryGst's Avatar
At Laguna-Seca last weekend, I got the chance to observe my coolant temps and oil temps and learned that the reported coolant temp becomes sticky at 194 degrees F. (i.e., it never rises higher, regardless of the actual temperature until, I'm told, it reaches 221+ -- which, not surprisingly, never happened). In effect, the coolant gauge becomes an idiot light once the coolant has become fully warm. Oil temperatures seemed accurate but never rose anywhere close to becoming a point of concern. So this topic's no longer of great concern. Still, I find it offensive that Porsche feels the need to "reassure" owners that all is fine by installing a gauge that doesn't actually work properly!
Old 05-03-2018, 03:46 PM
jscott82
jscott82's Avatar
AC condenser is in front of the left radiator.
There is a small oil/water heat exchanger on top of the motor to cool oil.
There is no cooling for the trans. But stay tuned to my spec Cayman build thread. I have a pretty cool solution coming.
There no real cooling for the power steering. But if you look at the hardlines, Porsche put a couple of extra loops under the chassis to help. May be able to augment those rather than installing an additional radiator
I haven't run the car yet, so can't speak to expected temps. But the car will be fully instrumented to capture then when I do
Old 05-03-2018, 07:14 PM
GryGst
GryGst's Avatar
@JScott82: thanks! It's been surprisingly hard to dig up technical information about these cars. Not sure if that's because the owner demographics are different from that for other track cars I've owned or because there's a presumption that "if Porsche built it...". Regardless, I appreciate the insights.
Old 05-04-2018, 10:44 PM
jscott82
jscott82's Avatar
Agree.. we need to wake this forum up
Old 05-05-2018, 12:32 AM
mgent
mgent's Avatar
GryGst,
I’m interested in this topic as well... I have a Cayman S, and have installed the 3rd / center radiator... Even so, I will see oil temps up to 260/270. In addition I have PDK, but haven’t seen a transmission fluid temp yet, but have concerns about how hot it is getting. I know BGB(?) makes an oil cooler that runs off of the tranny or diff, but I think its only for 987s, and haven’t seen a specific engine oil cooler for a 981.
mark
Old 05-05-2018, 04:41 PM
GryGst
GryGst's Avatar
@MGent: FWIW, I wouldn't be concerned with oil temperatures of 260-270 degrees, provided you're using a quality synthetic. In my last track car -- tube-framed, mid-mounted LS3 motor mated to a Porsche G50 gearbox (flipped upside down) -- oil temperatures were regularly well over 275. When we had the oil tested, the results showed few chemical indicators of engine damage/wear. Might never "feel" right to you, but I think the jury is still out as to whether there's actually a problem to solve here.
Old 05-05-2018, 05:36 PM
jscott82
jscott82's Avatar
Tell us more about that car!!!
Old 05-05-2018, 06:38 PM
GryGst
GryGst's Avatar
PM sent...
Old 05-05-2018, 07:38 PM
zedcat
zedcat's Avatar
Try searching ebsracing,com. They have the GT4 technik bulletin which has high level descriptions of most systems including cooling. (I had a PDF on a hard drive but lost it...) Not sure how similar it is to other 981s but may be worth a look. And FWIW my observation is the GT4 and GTS can handle advanced/instructor group DE sessions (20 to 30 min) with no temp issues. I've driven GT4 at COTA in summer. At least for MTs. PDK in GTS I'm not certain. Another observation- this sub forum is a bit quiet. The 987-981 forum is more active and also the DE/Racing forum. Best of luck.
Old 05-05-2018, 08:33 PM
GryGst
GryGst's Avatar
@ZedCat: thanks for the post. I've been around the track scene for years, but I'm new to owning a P-car (I've driven many but never owned/maintained one). Much obliged...
Old 05-10-2018, 06:37 PM
badabing
badabing's Avatar
Originally Posted by mgent
GryGst,
mark
If your car is PDK it should have come with the 3rd / Center radiator from the factory ???
Old 05-11-2018, 03:12 PM
GryGst
GryGst's Avatar
@MGent: Hi Mark. My understanding is that oil is cooled by an air-to-water cooler located on top of the motor, so -- given that your oil will ALWAYS be hotter than your coolant once the car is warm -- why would you expect you oil temperatures to be significantly lower with the addition of the third radiator? Maybe I'm not following the bouncing ball here...
Quick Reply: 981 fluids and cooling <= a couple of quick/easy questions
