Anyone install sequential shift lights?
I am trying to install sequential shift lights and would like information as to where to tap the wiring for the RPM signal.
What type of shift light kit are you using? I can do some more digging but I'm pretty sure you're going to need a can/kline/obd to tach adapter. Something like this Dakota obd tach adapter.
It's a 10 light sequential, model A-10 from Europe, 3 wire hookup (12v, ground and RPM).
i have been searching the web for days and found write ups on other models, 996 could use pin 9 on the OBD, it doesn't work on the Cayman. Tried all yellow wires on the instrument cluster, and green wires on the DME, all to no avail.
now, I'm wondering if it's not compatible or broken!
Thanks all!
Tapped directly at the ECU, top harness #6 green/blue wire. Works fine, just a little extra wire run from the back to the dash.
