Hard Wired Valentine 1 to 718
I have the V1 mirror mount, as well.
I was going to look at hardwiring right into the switched lines in the overhead dome light, using RJ11 telephone cable. I hear that makes for a shorter and easier installation.
I did mine to the wires in the overhead console, took about 10 minutes with the Blend mount 15 inch cable... Works great... Only drawback is if you want to use the remote display you would have to run a wire down a pillar...
