2006 s price check
2006 s price check
Hello to the board..
In the market for another toy. Came across a 2006 s with minimal options. Car has 26,000 miles through a dealer asking 29,500
My first question is the IMS issue?
At that price am i better off with a newer non S
Peter
Peter
Risk is less than 5% maybe less than 2% depending on who you listen too.
Great driver. Buy it. Take the risk and have a blast.
From what I have read, the level of risk depends on if it is an early 06 (higher risk) or a late 06 (lower risk)? Also, the thought is that lower mileage cars have higher risk. I say "higher" risk but the overall risk seems to be less than 1%. No expert here, this is what I've gleaned from my research.
Some early 987 Boxsters used 986 engines which had the class-action-lawsuit IMS bearing, but don't think any Caymans were shipped with the 986 engine. Haven't heard that early Caymans are worse, but you could be right - I dunno. I do think the IMS bearing issue on 987's is way overstated, and probably would not even be talked about if it were not for the 986 issue. I would not argue with your 1% estimate. Not sure how many people post on the various Porsche forums, but in the 3 years I've been following them I've only seen one confirmed IMS bearing death, but probably thousands of posts on the "issue".
That price seems slightly high to me, but I've not been looking lately. Personally, I prefer the Base to the S, but I know I'm in the (tiny) minority. If it were me, I'd try to find a 987.2 Base for similar money, but they are hard to come by.
=danschy;14358445 If it were me, I'd try to find a 987.2 Base for similar money, but they are hard to come by.
That was my decision also.
And yeah, it will may take some time to find one. There were only about 5200 987.2 imported to the US, including both base and S models.
The 987.1 Boxster was introduced in 2005 and as noted above some early 2005 cars were built with the old M96 motor with the more problematic bearing.
By 2006 model year the Boxster had the new M97 engine with the new bearing.
All US Caymans were 2006 models (or later) and were built with the M97 motor with the better IMS bearing.
Not sure if altonj plans to elaborate. The other big bucks item is bore scoring, but I believe that is also pretty rare and typically caused by inadequate oil flow, either by oil starvation on the track or high revs with cold oil. Much more likely are AOS and water pump failures, but although those may strand you, the are not huge expenses. Many recommend periodic replacement "just to be safe". I have 50k miles on my Cayman and have replaced neither. If you plan to track the car, going to a 987.2 is even more prudent.
