Price Check - 2006 Porsche Cayman S
I am looking to buy one but not sure what I should offer. Let me know what you guys think!
2006 Porsche Cayman S - Grey Ext, Black Int, 65k miles, manual
minor cosmetic rock chips on front and rear. some visible wear interior on the center display console.
Replaced fog lights with LED Spars
H&R wheel spacers to replace the factory spacers
Replaced the side intake vents with the Boxster style
Lightweight Flywheel + sprung clutch + pressure plate (these links are what I purchased)
IMS bearing replacement from LN Engineering (if you aren't familiar, this is a critical replacement to ensure that the engine doesn't brick itself, read up on it if you are curious - or I can explain in person)
Full exhaust + high flow headers from Fabspeed
IPD Intake Plenum and Throttle body from the GT3 engine
HPD Clear Engine cover (not installed)
3M crystalline window tinting (the good stuff)
Replaced OEM paper air filter with a cleanable high flow cloth filter
Replaced failed air oil separator with OEM.
Replaced failed shift linkage cable with OEM.
Replaced spark plugs at 50K miles
