958-secondary transmission pump failure
I have 958 cayenne and the light on display and deactivate start stop function. scanner shows p0c2: transmission secondary pump- return signal to low.
I research and discovery can be failure on circuit ( fuse, relay, transmission pump, transmission pump driver, harness etc)
any ideas for diagnostic? where stay locate relay transmission pump on 958 and whats number is ? how do i test the pump? thanks
