PLEASE HELP! 957 Turbo front sidelight fogging
One of the front sidelights located under the headlamp on my 957 turbo is misted up due to condensation, how do I get access to this to remove it please? Ive just spent ages trawling the web but cant find the answer anywhere, don't want to remove the front bumper unless I really have to..
If you find your light is damaged or cracked, I should have a good used one of these Driver's side lights from my '09 Turbo S as I'm updating to 958 lights on my Misha widebody build. Should be back by the body shop on Monday where I could pick it up.
Let me know.
Let me know.
The drivers side is a pain to remove. The passenger side is much easier. You do need to pull the front bumper cover off to access or tilt it down while keeping the washer tubing in place. The headlight washer plumbing gets in the way and I could not remove the washer jets as they seemed to be glued in so I gently pried the old light out and pried the new one back in luckily without breaking anything.
