Sponsored By:
Sponsored By:
Proper Air Pressure
Old 04-24-2017, 10:48 AM
Mike41
Mike41's Avatar
Default Proper Air Pressure
I have a '12 S with 21" All Season Continetial Tires DW06?
What setting should I use in the dash controls for TPMS?
20" All Season
21" Summer tires
My dealer keeps setting them to 20" All Season with pressures of 38 front 43 Rear.
I think the 21" Summer Tires is 35 front 39 rear.
Which setting is correct for the 21" All Season?
I plan to ask my dealer at some point wanted to know what others are doing.
Thanks,
Mike
Old 04-24-2017, 12:07 PM
deilenberger
deilenberger's Avatar
Received 1,140 Likes on 758 Posts
I would use the 21" settings. Those are slightly softer settings probably because of the less compliant sidewall of the lower profile 21" tire.
Old 04-26-2017, 11:48 AM
125shifter
125shifter's Avatar
I could be wrong, but I thought the dash setting for the tire OD change. The door jamb sticker is the most reliable source of correct tire pressure for any street car.
Old 04-27-2017, 08:44 AM
Andy E.
The V8 Porschephile
Andy E.'s Avatar
21". The setting may also vary for full or partial load.
In my neck of the woods, potholes that can swallow a micro-car, are a year-long affair. For this reason, I bump up the pressure by two pounds on all four.
Quick Reply: Proper Air Pressure
