Should I vinyl wrap my window pillars?
Old 04-21-2017, 08:30 PM
RJDthecayenneguy
RJDthecayenneguy's Avatar
Default Should I vinyl wrap my window pillars?
Been wondering lately if my pepper would look better with gloss black window pillars and window trim. Do you think it would look better wrapped, and if so, what color? Or should I leave it as is? Open to comments and suggestions!
Old 04-22-2017, 11:11 AM
hcrubg
hcrubg's Avatar
thinking the same thing, matte black though...
Old 04-22-2017, 12:57 PM
RickDC
RickDC's Avatar
You could also plasti-dip them - it's a quick and easy change if you don't like them and cheap as well..
Old 04-22-2017, 01:04 PM
808Bill
808Bill's Avatar
yes
Old 04-22-2017, 08:19 PM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
I actually like the silver trim, but not on silver cars. In your case, yes, the contrasting black would look better.
Old 04-24-2017, 09:57 AM
Avec
Avec's Avatar
I actually had to look at mine to see what I had. Mine are black from the factory. A GTS thing? I recommend black
Old 04-24-2017, 11:07 AM
SRS
SRS's Avatar
Here's the before and after on my pillars. I wrapped the pillars and plasti-dipped the trim. I also did the door handles and trim piece at the bottom of the door, but they got messed up, so I took that part off.
Old 04-24-2017, 05:39 PM
RJDthecayenneguy
Looks great! I ordered gloss black vinyl with the intention of wrapping the pillars and window trim. Did you attempt to wrap the trim at all?
Also, is there a noticeable difference in person between the matte black plasti-dip and the gloss black vinyl?
Old 04-25-2017, 10:33 AM
SRS
SRS's Avatar
I didn't even attempt to wrap the trim. I was reading this thread about plasti-dipping everything, and they said that the pillars were getting rubbed off when they closed the door, so they wrapped them instead.
https://rennlist.com/forums/porsche-...-to-black.html
I didn't put enough layers of plasti-dip on though. When I buffed the car, I tapped the trim off, so the buffer wouldn't grab the plasti-dip. The tape ended up sticking to the plasti-dip and it came off when I removed the tape.
The difference in the matte black and gloss vinyl isn't bad. I like that they are different from each other.
Old 04-25-2017, 11:24 PM
Bosty
Bosty's Avatar
Default Gloss Vinyl
https://rennlist.com/forums/porsche-cayenne-forum/730267-
I had door handles and door trim painted body colour.
The window trim was wrapped matte black. If I had to do it again. I would have used the gloss. I think it matches the overall appearance better, and doesnt look like it was an add on.
plasti-dip-silver-window-trim-to-black.html
My vote is gloss black vinyl!
Old 04-28-2017, 02:03 AM
boxsternewbie
boxsternewbie's Avatar
black 958's come that way, with the black window pillars, or at least mine did
Old 04-29-2017, 04:17 PM
RJDthecayenneguy
Default UPDATE
Just finished up wrapping the pillars and window trim in gloss black vinyl from VViViD Vinyl.
Turned out great, very easy to do if you're willing to take the time to do it right. I think the results speak for themselves!
Old 04-29-2017, 05:04 PM
Petza914
Petza914's Avatar
I actually like the middle "work in process" pic the best with the black pillars and silver door and window trim.
Old 05-01-2017, 06:15 PM
SRS
SRS's Avatar
That's what it looks like now. I taped the plasti-dip off so my buffer wouldn't grab it, then when I peeled the tape off, the plasti-dip came off anyway.
Old 05-01-2017, 08:46 PM
uphoto
uphoto's Avatar
How do the pillars come off? Pretty simple to do?
I would rather wrap them than plastidip
Quick Reply: Should I vinyl wrap my window pillars?
