Do you have to jack up the Cayenne to do an oil change?
Old 04-10-2017, 10:46 AM
kino1161
kino1161's Avatar
Default Do you have to jack up the Cayenne to do an oil change?
Just wondering if I can do it with the truck raised to its highest setting? Thanks!
08 GTS
Old 04-10-2017, 11:12 AM
tjrob2000
tjrob2000's Avatar
I don't have the air suspension and can do it without jacking (although I did jack it slightly so I could visually find the second drain plug). Should be easily doable on highest setting.
Old 04-10-2017, 11:54 AM
kino1161
kino1161's Avatar
Thank you.
Old 04-10-2017, 12:20 PM
Avec
Avec's Avatar
I found that if I drove the front wheels onto a 2x10 or 2x12 (12" piece for each side), then raised the car to max height, it was just fine to change the oil, and gave me plenty of room without feeling crowded
Also 08 GTS
Old 04-10-2017, 12:50 PM
TomF
TomF's Avatar
08 GTS
It is very easy with it set to "special terrain" height. If you have PDCC, it is more involved to get to the filter, (and messy) but completely doable. Remember, there is only ONE drain plug on the 4.8!
Cheers,
TomF
Old 04-10-2017, 03:48 PM
kino1161
kino1161's Avatar
Avec, thank you for that information.
Also, thank you, TomF! Everywhere I read they say there are TWO drain plugs! So there is only ONE? What is everyone talking about?
Old 04-10-2017, 04:54 PM
MJG911
MJG911's Avatar
I can change on my 2015 just by raising air suspension.
Old 04-10-2017, 07:30 PM
TomF
TomF's Avatar
There are two on the 955. The 957 has only one. There is an adequate DIY here:http://www.pelicanparts.com/techarti...Oil_Change.htm
Cheers,
TomF
Old 04-11-2017, 08:30 AM
kino1161
kino1161's Avatar
TomF,
The DIY link you just gave says there are TWO.... ????
I have an 08 GTS.
Old 04-11-2017, 08:40 AM
thescratt
thescratt's Avatar
Maybe I am being over cautious here. I have worked on my Cayennes by raising them using the air suspension. Most involved job I did was replacing the air-suspension compressor.
In all cases I have put axel stands under the car at lift points just in case. Mainly because Darwin Awards.
Old 04-11-2017, 11:27 AM
Wisconsin Joe
Wisconsin Joe's Avatar
TomF,
I have an 08 GTS.
The 4.5 in the 03-06 (955) has 2 drain plugs. The oil pan (sump) goes over the front axle and has a "hump" in it. If you only drain one, there is a fair amount of old oil left.
The 4.8 in the 08-10 (957) has only one drain plug.
Old 04-11-2017, 12:00 PM
TomF
TomF's Avatar
TomF,
I have an 08 GTS.
Read the fine print- it says the MY 2008- onwards have only one.
Cheers,
TomF
Old 04-11-2017, 01:58 PM
kino1161
kino1161's Avatar
Got it. Thanks, all!
Old 04-11-2017, 05:26 PM
stronbl
stronbl's Avatar
My 958 has air suspension and I raise it to max up and can easily change the oil at that point from underneath. Yes, I use a couple jack stands as a safety precaution too.
Old 04-11-2017, 07:33 PM
John Welch.
John Welch.'s Avatar
I have been crawling under the car with the suspension set at max and the setting "locked", but holy crap, I should have added some jack stands too.
I won't be doing that again.
Quick Reply: Do you have to jack up the Cayenne to do an oil change?
