An expensive day - what else might be next?
I have a CTT 2007 with about 74,000mi on the clock. It has been serviced and generally well cared for, and I have owned it from being an ex-demonstrator. I have replaced the battery (single battery only) as had intermittent starting problems - now 1:20 starts is a problem but giving it more time it then starts.
But yesterday, I loud rhythmic sound started and some other banging. Took it to a Porsche Centre in the UK, and have been told that:
- one of the rear brake shoes has fractured and damaged the thermal protection wall. Both need replacement. Car not safe to drive. Not a cheap repair.
- the drive shaft bushings and bearings are worn and there is now play in the shaft - needs immediate replacement. Car not safe to drive. Also not a cheap repair.
- there is an oil leak from the engine - and they want to clean and spray paint the exterior to detect from where the leak is coming - sounding like it will be expensive.
I am not looking to buy a new car as I am starting my own business - as much as I would like to have a newer Pig.
But my question to the forum is, with a 10 year old Cayenne Turbo, what other big ticket items are known or likely to fail or simply need replacement due to wear and tear?
Not meaning brake pads or discs or wiper blades - but transmission? Clutch? Engine gaskets?
Trying to make a judgement as to how much else is likely to go wrong - recognise it is a bit unknown as every car's history is different....
The only small rainbow is that they are discounting parts and labour due to the age of the car....
...- one of the rear brake shoes has fractured and damaged the thermal protection wall. Both need replacement. Car not safe to drive. Not a cheap repair.
-there is an oil leak from the engine - and they want to clean and spray paint the exterior to detect from where the leak is coming - sounding like it will be expensive...
I won't disagree that bad brakes are unsafe to drive, but this diagnosis leaves me with more questions than answers.
The Cardan shaft (drive shaft) is known for tearing out the bearing support. You are in the right time frame for it. The dealer will tell you that you have to replace the whole thing (not cheap), but there are other ways to address it that are far less.
How bad is the leak? Any idea where it's coming from (general area)? While the "clean and spray paint" sounds good in theory, a simple cleaning should be enough. There are a couple places that leak that are not that big of a problem, and again, the dealer will tell you it's a big, expensive fix, while it can be addressed for a lot less.
Originally Posted by CTTS520
I'm just guessing here but could he be talking about the parking brake? Also, Porsche didn't make the Cayenne in 2007. @the OP, will you double check the year?
So MY of OPs car might be 08 and the car itself is manufactured in 07. Hence the 07 deisgnation by our standards ;-)
Thanks for the responses.
That is correct - apparently it is applied as parking brake but the Porsche tech said it is also partially engaged in general breaking.
The problem I have now, is that the car is already at the centre and not in a state to drive away. So DIY repairs would be logistically tricky particularly as I do not have a garage. I have no doubt that they are following standard product/service guidelines to use authentic Porsche parts - hence full Cardan Shaft replacement not just the bracket - hence drain my wallet. In any event the car was soon due for a service.
Further internet searches resumed in Youtube videos of alternative repair parts for the Cardan shaft support bracket - which I could probably manage to do myself. The brake shoes probably not.
Generally, more interested in what else is not the list of "likely" failures at this point? May help me to proactive repair rather than failure repair. Any thoughts?
No idea on how to reconcile US MY designations and ROW year of manufacture. It is a facelift model before the new model in 2010 (UK time).
It's a 957, don't go any further Get it done and enjoy the car. Try to find a reputable porsche independent mechanic to work on your ride next time.
If you find one and want to be on the safe side, change all the oils (engine, differentials, transmission ...), change the filters, spark plugs, ignition coils & battery. Have them look at all the bushings as well. Drain the passenger side IC oil that has accumulated there and change all the o-rings. Install an oil catch tank to more easily drain the vented oil. Get the glued coolant line tapped with a screw. Rebuild the o-rings on your air compressor (the company that sells them is from the UK and they cost like £15 or so, search on ebay.co.uk).
IIRC, this should be it and it will cost you about £1k in parts, you don't need to buy almost anyhthing original from Porsche, OEM stuff is equally good. Get a good indy as I mentioned and you'll be set.
That should give you a looot of carefree miles. You car does not have a "clutch" per se (well, it does but not the one you're thinking of), it has a hydrodynamic torque converter. It rarely goes bad.
Search for "jimi fix" here on the Cardan shaft that will cost you a bicycle inner tube and zip ties to fix. Any garage can replace drum brakes on a parking brake and you can certainly drive with a bad parking brake.
Find a good Indy if you can't DIY. The cost of a tow added will be cheaper at the end of the day. That dealer tech sounds incompetent and is looking to fleece you hard.
Originally Posted by chsu74
Ha Ha Ha.. what a load of crap. He is right if you are rallying and need to drift around corners which I am certain you are not on street roads.
Originally Posted by deilenberger
Exactly what are you doing with the bicycle inner-tube?
https://rennlist.com/forums/porsche-...with-pics.html
