AC recharge valve replacement
Old 03-14-2017, 07:38 PM
rymo926
rymo926's Avatar
Default AC recharge valve replacement
I have a leaky AC recharge valve on my v6 955. Anyone have tips on replacing it. Thanks in advance. Rymo
Old 03-14-2017, 08:12 PM
nodoors
nodoors's Avatar
Sorry to be blunt, but if you have to ask this question, then you need to take it to a pro.
You will need to buy a bunch of specialized tools and obtain knowledge to use them like vacuum gauges, a powerful vacuum pump, etc. that are not worth buying unless you intend to fix more HVAC systems in the future. In other words, this is not a simple DIY.
Depending on how badly it is leaking and if you give not a poop about the environment then you may be able to get away with recharging it for a while until the refrigerant to oil ratio gets out of whack enough that your compressor burns up.
Old 03-15-2017, 07:57 AM
griffiths
griffiths's Avatar
Rymo,
Frankly, if you figured out one of your R134a schrader valves is leaking that's pretty savvy for a DIY'r.
Its not common to find a rather new vehicle with a leaky valve, but
things happen.
If the valve is simply loose you can try snugging it up (RH thread, CW, don't over tighten) with a tool like below (similar to a common tire valve or bicycle valve tool, however R134a valves then to be deeper in their bore). If snugging up the valve does not resolve the leak you will need to have the vehicle serviced (removal of refrigerant, insert new valve core, evacuate, charge and test).
Not sure how much refrigerant you may have lost. You could try to have the system 'topped off' (adding refrigerant), but if the system has lost a lot of refrigerant you will need to have it evacuated, charged and tested.
Running systems that are low on refrigerant is not good for the compressor.
The compressor needs a constant flow of refrigerant oil moving through when it is 'on' to keep things lubricated; it is the refrigerant that carries the oil. Although you may have a low pressure cut off switch you can't rely on them all the time.
Griffiths Tech
Old 04-25-2017, 11:13 PM
pp000830
pp000830's Avatar
Received 1,449 Likes on 1,020 Posts
Originally Posted by griffiths
Rymo,
things happen.
Griffiths Tech
a one simply put a cap on the valve with a good O ring to plug the leak seeing that shrader valves are known to leak. On home systems a brass cap with O ring is standard.
Old 04-26-2017, 08:09 AM
griffiths
griffiths's Avatar
That's a possible solution but not the ideal.
Static pressures can be anywhere from 70 to 100psi+. Operating pressures,
low 20-40 and high 160-300+ psi. Sooner or later a 'cap' over the service port will leak.
Quick Reply: AC recharge valve replacement
