Great 955 TPMS value
If anyone needs to get TPMS sensors or replace your old ones, i've ordered 3 sets of the OroTek brand on eBay, model number OBE005 for about $15/each (so $60 a set of four, free shipping) and they work great! Preprogrammed, just need to be installed, system will learn the sensors in a few miles. I have an 06 955 Turbo S, but should be good with all 955/957's. No need to spend a fortune!
Not if its not equipped with it. Apparently it was an option. Does your car read "No monitoring" when you first start it up? If so its turned off in your dash menu options. Get the sensors, turn it on via the menu options and you're good.
If not, then it won't work...
Are all TPMS sensors compatible with every car brand (I would think so, would be stupid and expensive to make many different types that are incompatible, but the auto industry does a lot of stupid stuff)?
No, different brands use different frequencies on which the sensors communicate with the control receiver. I think the 955 & 957 Cayennes use the 233 MHz frequency, but double-check before buying anything.
Just had a set of these installed in my winter wheels. Unfortunately the tire shop is really close to my office, so they hadn't learned the system by the time I got back to work.
Hopefully on the drive home they'll initialize and start reading...
ID format (DEC/HEX); Assume D = Decimal. Don't see any significance.
latest complete guide here
http://itmautoparts.com/application-list/
I have never figured out what it takes for the units to register. Sometimes it happens within the first mile, sometime takes longer.
I switch from summers to winters and back every year, different behavior every time.
