LED turn signal - these ones seem really cool, anyone try it out?
Old 11-09-2016, 10:54 PM
raolc
raolc's Avatar
Default LED turn signal - these ones seem really cool, anyone try it out?
I was looking at getting the clear turn signal / side lamp + smoke tint from suncoast along with some LED light replacement options when I ran into these:
http://store.ijdmtoy.com/OEM-Style-P...s-p/75-073.htm
I also see (what I assume) is the same part here on a german site: https://www.sw-tuning.de/SWLight-LED...TS::42229.html
It seems like the install is really easy and they look awesome! Anybody hear about this product before?
Old 11-10-2016, 05:23 PM
raolc
raolc's Avatar
Went ahead and bought it along with some license plate LEDs, will keep you all posted!
Old 11-10-2016, 05:27 PM
touareg
touareg's Avatar
I noticed this:
http://www.ebay.com/itm/07-10-Porsch...WlJz1A&vxp=mtr
But for a 957, was wondering if anyone got one of these.
Old 11-11-2016, 09:53 AM
Petza914
Petza914's Avatar
Received 6,167 Likes on 3,931 Posts
Originally Posted by touareg
I noticed this:
Those actually look pretty good. If I hadn't deleted the side markers with my Misha kit, I probably would have opted for something like that. I still don't understand why the stock lights are designed to shine down onto the tire/wheelwell as well as out to the side.
Old 11-11-2016, 06:54 PM
touareg
touareg's Avatar
I have a theory on the tire well light.
I think it does 2 things, lets cars see it from the side, because it is supposed to be a turn signal light.
If you look at the lights, they have a blanked off socket for a bulb. I wonder if in other markets, this was a seperate higher wattage bulb, that is tied to the turn signal, and will flash brighter than the side marker light, but cause both the wheel well and the side to apear to flash.
If the side markers are off, it works just like a regular flasher.
If I could find a socket I would modify mine like this, and see if it triggers a code or not:
Old 01-31-2020, 10:18 PM
chaudanova
chaudanova's Avatar
Old thread, but has anyone ever got these successfully wired up? I got them physically in, but the wiring has them just on solid amber, even with the white wire connected to 12v.
Old 01-31-2020, 10:52 PM
Petza914
Petza914's Avatar
Your front module MAY be coded to have those lights be only side markers instead of actual turn signals. You would need a PIWIS, Durametric Pro (not Enthusiast) or similar tool to be able to change the coding of that module to use those lights as turn signals.
Old 01-31-2020, 11:46 PM
RSbob
RSbob's Avatar
Clear/amber LED marker. Updated URL. They do ship directly from China if that is a consideration these days
Quick Reply: LED turn signal - these ones seem really cool, anyone try it out?
