957 Switched 12v outlet install for Dashcam
Old 08-29-2016, 04:06 PM
touareg
touareg's Avatar
Default 957 Switched 12v outlet install for Dashcam
Got tired of plugging and unplugging under the dash, and not finding any switched 12v outlets (rear, center back seat, under passenger front seat or ash tray area) after multiple reports and me testing, none shut off after checking each one 20 minutes later.
Anyways, I got an add-a-fuse, a 12v barrel female plug (to make it flexible in the future) and some bits lying around my shop. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Was able to bolt the ground to the crash bar with two 11mm wrenches, a short bolt, 2 washers, a ground loop and 2 nuts, one to tighten and another to lock it down so it wont back out.
Thought the first fuse point would work in the picture below, reading from a 958, it did not.
Then was able to find an un-used 12v switch fuse block point in Number #47.
This is all installed without cutting a single wire on the car, nor modifying anything, which I like.
Old 08-30-2016, 12:17 PM
Petza914
Petza914's Avatar
Received 6,161 Likes on 3,926 Posts
Nice work. I installed a 12v outlet that has a dual USB in it in the plastic under the driver's seat which is where I plug in my phone to charge. Don't have to leave the ashtray cover open anymore.
Old 08-30-2016, 10:59 PM
touareg
touareg's Avatar
Cool, you have any pics? I may go back and modify this one, its 10amp fused, so I can run a few more things off it.
Old 08-30-2016, 11:13 PM
Petza914
Petza914's Avatar
It doesn't look like I do. Pig is at the body shop in the midst of the widebody kit install, but I may be up there on Friday and will try to remember to take a pic.
Old 11-04-2016, 04:11 PM
nodoors
nodoors's Avatar
I am running my dashcam, valentine1, and the MOST converter box for my stereo from an add a fuse in on that same side. I used a screw down under the glove box for ground that I accessed by taking off the black cover in the passenger footwell. There are many spots you can tap into for switched power on that side. Nice to see another dash with the carbon fiber trim. I like the red stitching too!
Old 11-04-2016, 08:21 PM
mudman2
Moderator !x4
mudman2's Avatar
Yo T
I use the diagnostic socket to feed power to cam and V1
Old 11-17-2016, 01:53 PM
wkearney99
wkearney99's Avatar
This is great, thanks for posting it. I'm adding one to my '17 958 and using this as a starting point.
I found there's fuse panels on both sides. Any recommendations on which ones to tap for power?
Old 12-22-2016, 12:09 AM
touareg
touareg's Avatar
I think I found the passenger side had more free space?
Old 12-22-2016, 09:11 AM
wkearney99
wkearney99's Avatar
I went with an in-line 12v-USB module for mine.
http://amzn.to/2hKYqCO
There's an equal amount of room on both sides in a '17. At least for something like the in-line module. I didn't want to introduce the potential for loose sockets, corrosion or issues with heat dissipation that can come along with burying an accessory socket behind panels. Most of the time it's fine, but I had an adapter malfunction some time ago and I'm not eager to have that happen again.
I've yet to find a power take off point for the radio's "lingering" supply. As in, be able to stay running for the same extended interval as the PCM. On the left fuse panel there's only constantly-powered or tied to the ignition being in the started position (not just the 1st click).
Old 12-22-2016, 03:10 PM
touareg
touareg's Avatar
Nice, I thought about doing that, cheaped out though
Old 12-22-2016, 04:09 PM
wkearney99
wkearney99's Avatar
I was surprised to find something exactly like that for so little money. I'm sure there's something wretchedly inefficient about the design or something but it's working great thus far.
I'd still like to find a place in the wiring to tie into the radio's power or at least into the same 30 minute cut off circuit that the outlets have. Which, tangentially, I've confirmed, does cut off and stay off after 30 minutes. Although I suppose I'll have to revisit the fuses, I may have overlooked whether the circuit for them is handled ahead of the fuse or not.
Old 02-06-2017, 08:55 PM
Lionworks Auto
Lionworks Auto's Avatar
Toureg- great write up! Followed it to a T and installed this dash cam and a Bluetooth radio adapter which I hid in the lower passenger well. Now I have visual and tunes that shut off and on with ignition these forums are awesome. Thanks!
Old 02-06-2017, 08:56 PM
Lionworks Auto
Toureg - great write up! Followed it to a T and installed this dash cam and a Bluetooth radio adapter which I hid in the lower passenger well. Now I have visual and tunes that shut off and on with ignition these forums are awesome. Thanks!
PRUVEEO F5 Car Dash Cam with Wifi, APP Support IOS & Android System, 140 Degree Wide Angle Dashboard Camera Driving Recorder DVR for Car Vehicles https://www.amazon.com/dp/B01KZWMGFY..._31Xk69OZw1jGf
Pico 0956PT 10 Amp ATM Mini Blade Fuse Add-A-Circuit Fuse Holder https://www.amazon.com/dp/B001QRSBW0..._mGLmtqzfoR2ue
SMAKN® 12V 5A Female Car Cigar Cigarette Lighter Socket Plug Connector Adapter https://www.amazon.com/dp/B00RT5TE5Q..._73ZKMfCT237Ib
SNAN Cigarette Lighter Power Adapter DC Outlet Car Splitter With 2 USB Ports and 2 Sockets - Double Fuses and Independent Swithes (3.4A/90W) https://www.amazon.com/dp/B01G6R24CM..._hInYzDC9y5njX
GOgroove FlexSMART X2 Bluetooth In-Car FM Transmitter with USB Charging , Multipoint , Music Controls & Hands-Free Calling - Works with Apple , Samsun https://www.amazon.com/dp/B003PPGOC0..._uN41eiAGBGeVH
Old 02-07-2017, 07:18 PM
wkearney99
wkearney99's Avatar
Why not just use a 12v-usb adapter instead of the socket?
I went with a dual socket one to provide power for both the dashcam and a phone charger.
http://amzn.to/2kQdlwN
Old 02-09-2017, 09:43 AM
Lionworks Auto
Good idea too. I had already owned the splitter and the radio adapter from before so just went with it. Plus future flexibility.
Quick Reply: 957 Switched 12v outlet install for Dashcam
