Engine Squeal
Engine Squeal
Just started hearing this engine squeal. 2009 Cayenne S with 152K miles. Runs and idles fine. I hear the squeal when it first starts for about 15-20 seconds and then sometimes when idling. When I rev the motor it stops. I uploaded a video recording the sound here:
https://www.youtube.com/watch?v=itEFUM9D_hI&feature=youtu.be
Doesn't sound like a belt to me.
Any ideas?
Any ideas?
Received 5,388 Likes
Water pump?
I think you may be right. I took all the plastic covers off the top of the engine so I could hear the noise better and it definitely sounds like its coming from the water pump. The pulley is tight and I don't see any signs of a leak.
Any idea on how safe it is to drive until I can get it fixed?
I took the oil separator apart and the diaphragm pretty much fell apart as I inspected it. Not sure if it had holes before but it certainly does now. Will order a new one in the morning.
