955 CTT boost to intake o-ring list
Has anyone compiled a list of all o-rings needed to freshen up the piping from the turbos to the intake? I replaced the driver's side pressure pipe o-ring when I bought the my 05 CTT a year ago, but still have some leaking. Just replaced the valve cover gaskets and think sealing those up may be making the minor leaks in the piping worse under full boost.
More than likely your "charge pipe" seals need to be replaced. All of mine were sweating oil on my car at 46k miles. You can look at the parts diagram on Jim Ellis's website and compile of list of parts you need.
Whenever I change the oil in my Cayenne I make sure to drain the oil from the driver side lower charge pipe (turbo to intercooler) as oil will collects there -- about a cup.
