TPM keeps going back to BAR instead of PSI
2012 Cayenne , I change units to PSI and after a day or so they return back to BAR unit.
Is this a bug in the computer, or Im doing something wrong?
After you have all of the desired settings made, do you take the key that you were using out of the car and then lock the car with that same key? Page 38 and 39 in my manual. All of the settings are stored on the key and set to that key by locking it. I have also made a habit of storing the settings into the Driver's memory button.
If you get a 14 model you don't have to worry about switching. It is ONLY in BAR !!
To clarify, I was talking Oil Pressure. In my 2013 Boxster, one can select BAR or PSI. In 2014 Cayenne on my car, one does not have that option. I remember trying to set it to PSI (going nuts trying to locate it) and could not do it. So contacted my SA and he confirmed for me that it was not available on my Cayenne.
