Low oil pressure until warm up?
My oil pressure gauge on my 04 cayenne s reads 1 for the oil pressure until the car warms up. Then it stays around slightly below 2 and never moves from there. I don't hear any engine knocking nor am I getting a low oil pressure alert. Is this normal?
Thanks in advance.
Thanks in advance.
The V8 Porschephile
Davie, are you referring to the gauge to the left of the tachometer? If so, this is the oil temperature gauge as the temps that you describe are quite normal.
