Water pump R&R on base Cayenne
Thanks dorumac for the hint! I find it very hard to any car work based on words without figures or illustrations. Can anyone share some documents or webpages which illustrates how to do maintenance work on Cayenne V6? I think Touareg is good too since they are basically the same?
Bump on this anyone got any document that illustrates how to do the Water Pump change on the V6 3.2 Cayenne?
Also do you have to really drain the coolant from 7th radiator? What happens if I don't and just go ahead and remove the water pump - does all etc coolant in the car gush out of the water pump hole??
