CTT Oil Consumption
Old 07-18-2013, 06:35 PM
txhokie4life
txhokie4life's Avatar
Default CTT Oil Consumption
I had read that the CTT was bad for oil consumption.
It took me a few K miles after I bought my 2008 CTT @ 18K miles with an unknown oil, but being supplemented by Mobil 1 20W50. I was consuming
about 1 qt every 1K miles. Which is pretty much par for the course
as far as I was reading.
I finally got the chance to change the oil to Amsoil 20W50. I have had good
luck with Amsoil in my race car -- so I figured I would try it in my CTT.
To date -- it has used virtually 0 oil. I have been checking every 1K miles to see if any oil was needed, but its still on the full mark where i had it when I did
the oil change 6K miles ago.
Time for my next (first Amsoil) oil change -- I'll be spending the extra $$ and
filling the CTT back up with Amsoil
YMMV -- or your oil consumption may vary :-),
Mike
Old 07-18-2013, 08:31 PM
williamr91
williamr91's Avatar
I have 44k (44,019 to be exact lol) on my 04' CTT, I've only had it for 2k but it doesn't seem to eat much oil at all, maybe a fill line (on the oil bottle each k). My 06' CS ate a bit more about half a quart, but all in all I'm not sure why some eat so much, while other don't. 0w-40 M1 documented in both trucks since new.
Old 07-18-2013, 11:02 PM
JohnnyBahamas
JohnnyBahamas's Avatar
My '06 turbo finally has 53k and burned 1/2 a quart in 4000 miles. First oil it has ever eaten. 0W40 Mobile 1 changed every 3000 for the first couple of years and every 4000 since.
I like changing the oil. Best thing you can do for your engine.
Old 07-19-2013, 02:57 AM
mcbit
mcbit's Avatar
My recently sold 2005 CTT (197,000 km.) used 1 ltr. every 4000 - 6000 km. on 20,000 km oil changes since I bought it Dec 2010 at 87,000 km.
Old 07-19-2013, 03:28 AM
D2k
D2k's Avatar
Is 20W50 even safe long term?
Old 07-20-2013, 06:18 PM
user 83838290
user 83838290's Avatar
wooohoo, I just ordered 25 liters of motul 8100 x-clean 5w-40. my sucker burns a liter every 1000kms (or less ). I change my oil every 10 000kms (±6200 miles), but with the amount of oil it's burning, I pretty much run on fresh oil all the time
I found out that I can burn 2 liters in approx. 200kms - all it takes is to drive a steady 220km/h for about 45 minutes - until the gas runs out :-)
Old 07-20-2013, 08:35 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
1 quart per 1 km is considered acceptable by the factory.
Is 20W-50 on the approved oil list for the P!g?
Old 07-20-2013, 09:02 PM
user 83838290
if it has any kind of porsche approved spec, the temperature ratings are just a user preference.
Old 07-23-2013, 12:20 PM
Slow Guy
Slow Guy's Avatar
1 quart per 1,000 km is considered acceptable by the factory.
FIFY
0w-40 vs. 20w-50 is a viscosity issue not a temp issue. Yes temp plays a roll in the viscosity but temp is not the sole deciding issue.
I seriously doubt I'd run anything higher than a 10w-40 in the P!g.
Personally I run 5w-40 Motul X-cess (not sure of full name) which is a Porsche Approved Oil.
Old 07-23-2013, 09:10 PM
DWPC
DWPC's Avatar
Originally Posted by 993BillW
FIFY
I agree. I don't try to outsmart the tribology gurus who specified the oil for these marvelous engines; especially when I turn the key on a -15F morning after the car's sat for a few February days at Flagstaff airport. It's 0-W-40 for me.
Old 04-13-2016, 11:53 PM
Paris-Dakkar
2nd Gear
Paris-Dakkar's Avatar
Default excess oil consumption in a turbo
MAY be a sign of a pin-hole leak. You can go a long time with it, but you have to watch your oil like a hawk while you save up about $12 grand. :-( hopefully that's not your problem, but good to know.
Old 04-14-2016, 12:10 PM
Dan87951
Dan87951's Avatar
Check your charge pipe seals by the intercooler. They are known to leak oil. I would also check the valve cover gaskets. When I was shopping for a Cayenne everyone I looked at exhibited some form of leaks from the valve cover gaskets.
Old 04-14-2016, 06:11 PM
J'sWorld
J'sWorld's Avatar
Imo, there are a couple of items that contribute to excess oil consumption in the ctt.
A pcv system with a sorry *** oil air separator.
Sorry *** Journal bearing Turbos
Forged pistons and the particuilar ring package.
Piston clearances, and lateral gas ports in the pistons that are likely clogged with carbon.
Valve guides and seals depending on age and or mileage.
It's probably one of the most beat to death topics and yet very few will even take the time or spend a couple bucks on a catch can which would prob. eliminate 90% of the oil inn the charge plumbing.
One could replace the charge pipe seals at every oil change however they will still seep because oil puddles and sits there.
Burning oil lowers your octane and cloggs things up. It's not your friend.
Old 04-15-2016, 12:10 PM
69gaugeman
69gaugeman's Avatar
04 CTT with 222,000 km. Uses 3 litres in 20,000km. I'm more than happy with that. It freaked me out doing 20k oil changes as I come from an era just after the dino's left the earth. But the manual actually says 35,000km... I just can't do that. And it's easy to remember when oil changes are due....
Old 04-15-2016, 01:10 PM
BlackTurboS
BlackTurboS's Avatar
Default Manual
Here is a "snippet" from the official manual on the Cayenne's oil consumption. Luckily for me they don't list the consumption for the Turbo S - probably because they didn't want to be transparent about how much oil I burn in my turbo. I notice throughout a month to month period the more I "push" the turbo the more oil I tend to burn (very minor overall).
Quick Reply: CTT Oil Consumption
