Cayenne aftermarket Unit for a 2008 with Bose
Old 07-22-2013, 09:32 PM
GabePorsche
GabePorsche's Avatar
Originally Posted by ltc
It looks as though they cloned the main harness connector (made by Amp IIRC) for the Bose amplifier?
If so, then that cable runs from the back of the Chinese head unit to the rear cargo compartment and plugs into the speaker harness connector (I am assuming the Bose amp is removed at that time).
Without getting a shovel and heading to the cemetery to ask Larry, at first glance it should work.
Just out of morbid curiosity (like slowing down to stare at an accident), are you replacing a CDR23 or PCM in your P!g ?
And since its your first post, welcome to the P!g Pen, blah, blah, blah ....
The instructions for the plugs are as follows(copied from the eBay listing)"Please connect the speaker plug which you pull out from amplifier with our 3 meter speaker plug directly . After that ,there is some idle lines in the end of 3 meter long speaker plug,please connect these speaker cables to the speaker cables of our power plug one by one . In the end ,you can bypass your amplifier and use our built-in 4*45W amplifier ."
Thanks for the Welcome!
Old 07-22-2013, 09:34 PM
GabePorsche
Originally Posted by endless_corners
wonder if its running android
It's running Windows CE
Old 07-22-2013, 09:38 PM
GabePorsche
The max budget that I'm aiming for is $1100. If there's a solution that's plug n play, that would be Perfect!
Old 07-22-2013, 10:16 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Thanks for confirming what I thought they did.
Larry did a good job teaching me all that Bose electronics stuff ...
Old 09-24-2013, 03:10 PM
GabePorsche
The Parts are in and here they are. Where's the factory amp located? I was going to do it as a DIY project and having second thought. I did this same project in my Benz C class, but i'm thinking this one will be a lot more time consuming with the Bose system. This is going into a 2008 Porsche Cayenne...any advice is appreciated
Old 09-24-2013, 03:14 PM
GabePorsche
https://www.dropbox.com/s/k73zskyy8d...cheradio10.jpg
https://www.dropbox.com/s/57cpzhv6az...cheradio11.jpg
https://www.dropbox.com/s/y7ygn2h8bn...cheradio12.jpg
https://www.dropbox.com/s/rofji161kb...cheradio13.jpg
https://www.dropbox.com/s/suabcj6pbc...cheradio14.jpg
https://www.dropbox.com/s/in19eyfwyc...cheradio15.jpg
endless_corners
endless_corners's Avatar
[IMG]link goes here[/IMG]
Old 09-26-2013, 04:41 PM
crs051767
crs051767's Avatar
Hi. That just looks like this unit:
Amazon.com: Koolertron (TM) Car DVD Navigation with 7" Digital Touch screen and iPod BT RDS CAN-BUS for Porsche Cayenne: Car Electronics Amazon.com: Koolertron (TM) Car DVD Navigation with 7" Digital Touch screen and iPod BT RDS CAN-BUS for Porsche Cayenne: Car Electronics
Check the review & let us know how it works for you...
Old 09-26-2013, 08:39 PM
DWPC
DWPC's Avatar
Koolertron? Methinks it didn't quite come out the way the guy in the meeting explained it in Mandarin. At least we know they don't waste a lot of money on marketing focus groups.
Old 09-26-2013, 10:45 PM
westy66
westy66's Avatar
It would be worth a shot for $600. I hope it works for you. I would be worried I wouldnt be able to get it back together if it didnt work haha
Old 10-01-2013, 01:02 PM
GabePorsche
OK, Got it installed! I decided to take it to a professional and I'm glad I did! The wire that was shipped to bypass amp was way too short(by 6 feet) and was configured incorrectly. It looks factory and if you configure the display correctly, you can make the text orange to match the factory fonts...but I don't too much like all the orange fonts...
Old 10-01-2013, 01:05 PM
GabePorsche
Here's a pic of what's on my USB drive. They ran the USB cable & iPod connector to the glove box...so far I'm very pleased at the sound being that the amp was bypassed and it's using the built-in amp. The 2nd phase of the project will be having an amp installed.
I also purchased a backup camera and it works perfectly!
Old 10-01-2013, 09:05 PM
AdMan21
AdMan21's Avatar
Pics aren't showing for me. Once your finished playing with your new toy can you put of a review? Props for taking a risk and buying this.
Old 10-03-2013, 01:35 PM
GabePorsche
Old 10-03-2013, 03:11 PM
crs051767
crs051767's Avatar
This one looks different from the one that has a very negative review in Amazon. How does it sound compared to the stock system? Does it have equalizer? How does the Bluetooth sound at both ends of the call? Did you lose the display in the Odometer area? How pleased are you with the overall system? Thanks.
Quick Reply: Cayenne aftermarket Unit for a 2008 with Bose
