Here's your front end clunking
Old 10-01-2010, 03:23 PM
  #31
Eric_Shea
Eric_Shea's Avatar
Danke!
So the CTT arm bolts into the S... just a better bushing? I think I can grab one for $155.00
Old 10-01-2010, 05:59 PM
  #32
Cole
Cole's Avatar
Originally Posted by Eric_Shea
Danke!
NOOOOOOO!!!!!!
The CTT, S and Cayenne base arms are all the same. It is ONLY the CTTS arms that are different. So you want to shop for CTTS arms not just CTT arms.
Old 10-01-2010, 06:21 PM
  #33
Eric_Shea
Eric_Shea's Avatar
All years work in all cars? 2006 plus for a CTTS?
Old 10-01-2010, 06:23 PM
  #34
Cole
Cole's Avatar
I would imagine that since they did not actually change the chassis for 08-10 and only did a facelft that all the arms are the same.
Old 10-01-2010, 06:30 PM
  #35
Eric_Shea
Eric_Shea's Avatar
Arrrrrgh... not available through my supplier. Just the standard model at 157.00
Old 12-07-2012, 07:23 PM
  #36
VIPNiSS
VIPNiSS's Avatar
Does anyone know the factory torque spec?
Old 07-08-2015, 06:00 PM
  #37
cordsig79
cordsig79's Avatar
Bumping as the age of our Beta's are getting this as a common issue.
So I need to get the fronts done, and will be buying the Turbo S arms.. Should I also go ahead get Springs/Shocks or just try to see if this resolves rough rides.
Same with the rears.....should I be getting lower rear arms/bushings for a local suspension shop to press In/Out..
Old 11-15-2017, 06:09 PM
  #38
Dasblau
Dasblau's Avatar
My GTS does this clunking noise as well passenger side only in the front under hard acceleration in 1st gear. It's getting worse as time goes on.
Quick Reply: Here's your front end clunking
