Coolant pipes A-Z.
#453
#454
You can just remove the plastic holder and that will allow you better access and also enable you to move the looms around. I went underneath the vehicle to get to the lower hose. A cable clamp pliers are a must. While you are there get a 3/8 " T and replace the nylon one on the air or vacuum line just behind that holder. The brittle nylon will bust off and leave some in the line. I just used a pair of pliers to crush it up and put a straw in the crevice tool of the vacuum to suck out the bits. There is a little write up on this somewhere. I will look.
#455
Here it is. You must make a donation to renntech for access. Well worth it with many good DIY tutorials.
http://www.renntech.org/forums/tutor...ss-t-pipe-mod/
#458
Is that for sure mtnrat?
I`ve just bought a 2008 CTT and I`ve heard conflicting reports on the cooling pipe status - some say they're bulletproof but others say theres still a lone plastic pipe lurking in the bottom of the valley
Theres also mention that there is a pressed in/glued pipe on the water distributor that can come out - I have heard there is a revised part for this
#459
#460
#462
#464
Coolant pipes A-Z.
Just finished replacing the coolant pipes in my 05 Turbo...what a pita!!! also did the brake booster lines as well, another pita!
Thanks for the write ups in here as well as ECS Tuning instructions! And that vacuum tool posted in here is amazing!!!
#465
So I would like to do my 957, but nervous messing with the fuel rail for DFI, does anyone have to torque specs for all the things that come out?
Also how do I get the fuel out of there when things come apart?
