Auto On Headlight Retrofit? - '06 Cayenne
Old 03-21-2013, 09:58 PM
  #61
CarreraCup03
CarreraCup03's Avatar
Default light sensor
I just tested with a flashlight, and have located the light sensor. It is behind the rearview mirror on my non auto dim mirror. It is very easy to see from the outside of the car. Looks like a bunch of clear small LED lights ... kind of where the glue should be on the base of the mirror. If you have what I have described, you have the light sensor.
This is officially my last post on the auto dim switch, until my next one ...
Old 03-21-2013, 10:23 PM
  #62
Chaycek
Chaycek's Avatar
Awesome!
I'll look for it.
Old 03-21-2013, 11:21 PM
  #63
D2k
D2k's Avatar
Does yours look like this?
Old 03-21-2013, 11:39 PM
  #64
CarreraCup03
exactly like that!
Old 03-22-2013, 12:47 AM
  #65
virkdoc
virkdoc's Avatar
Carreracup please check it tonightttttttt
Old 03-22-2013, 12:54 PM
  #66
XR4Tim
XR4Tim's Avatar
Just so everyone knows, rain & light sensors changed midway through the '05 model year. Later Cayennes all got the same sensor regardless of options. Earlier Cayennes had different sensors depending on equipment. So if you have an early Cayenne without the auto-dimming mirror, this might not be a plug & play switch install.
Old 03-22-2013, 01:14 PM
  #67
Chaycek
Chaycek's Avatar
What about the 911's?
Did they change?
I have an 07
Old 03-22-2013, 01:16 PM
  #68
touareg
touareg's Avatar
Question is now, do you all have the coming home function after plugging in the switch.
I.e. after ignition off, can you now have the lights stay on for 15,30,60 seconds. Then shut off.
Should be able to enable this in durametric...
Old 03-22-2013, 01:56 PM
  #69
CarreraCup03
I do not have the coming home function, but may try to program using Durametric. My headlights just go off when ignition goes off.
More importantly, Sunset Porsche has the Porsche Auto switch for $56. Talk to Bob ... part number 955613235036N3.
Old 03-22-2013, 02:32 PM
  #70
virkdoc
virkdoc's Avatar
Damn porsche auto switch for $56.......and aftermarket costs more???
Old 03-22-2013, 02:36 PM
  #71
virkdoc
virkdoc's Avatar
Website for sunset porsche?
  #72
XR4Tim
XR4Tim's Avatar
Did they change?
I have an 07
997s have different sensors for cars with auto-dimming mirrors and without. Also, some 997s don't even have a rain sensor.
Old 03-22-2013, 03:23 PM
  #73
Chaycek
Chaycek's Avatar
Did they change?
I have an 07
I have the rain sensors but not the auto dimming mirrors.
Carreracup3 doesn't have the autodim but does have the sensor (led cluster)
Around the mounting bracket for the rear view.
Old 03-22-2013, 03:36 PM
  #74
virkdoc
virkdoc's Avatar
Hmmm this gets even more interesting...
Old 03-22-2013, 04:04 PM
  #75
Edward 96 Viper GTS
Edward 96 Viper GTS's Avatar
list price at porsche dealership, 114$. discounted to $90 including tax. i ordered thru bob at sunset porsche. $56 plus $7 shipping. total approx $64. worth a gamble to see if it works
Quick Reply: Auto On Headlight Retrofit? - '06 Cayenne
