Auto On Headlight Retrofit? - '06 Cayenne
Old 01-24-2012, 10:50 PM
CarreraCup03
CarreraCup03's Avatar
I am wondering if the cars are equipped with the light sensor and just need the auto switch. Has anyone tried this. I can tell you from experience Porsche does do this type of thing. I replaced my PCM to one with the phone buttons. I got a little bonus .. the new one was programmed with the in dash compass function. I plugged in my new PCM and there the compass was on my dash. I have read that you need some sort of thing under the seat etc., to have the compass. It was not an option on my car, I have the option list ... yet there the compass was.
Old 01-25-2012, 09:32 AM
yeldogt
yeldogt's Avatar
Porsche builds each car -- the wire harness are different depending on the options. My 06 did not come with dimming mirror -- one would have thought that the wire loom up to the mirror would be the same since all the cars have the auto wipers .... nope -- no wire to power the mirror.
I was told it is the same with the light switch -- no wires and a different connector.
Old 01-25-2012, 09:36 AM
CarreraCup03
thanks
Old 03-14-2013, 12:59 PM
virkdoc
virkdoc's Avatar
i still feel it can be done...the sensor is on the rear view mirror if Im not mistaken, so put in a new switch on the dashboard and run the wires from the rear view to the button?? Is it possible??
Toby??
Old 03-15-2013, 06:54 PM
Travis
Travis's Avatar
There is a link on renntech of a member doing this very thing.
Can I Replace A Standard Switch with Auto Headlight
Looking on eBay, the switches go for about $20 bucks. Programming to enable the function is dependent on your dealer rates...(PIWIS to enable Comfort Light function)
There are other items for me to address before I get to this, but this doesn't look too bad given it appears to work.
Old 03-15-2013, 09:26 PM
CarreraCup03
How do you remove the headlight switch. I cant get the old one out. I pushed in and turned counterclockwise like I read about. Does not come out. Any Ideas?
I just bought the VW switch on Ebay. I am going to try it. Will let you know how it works out.
Old 03-16-2013, 12:05 AM
Travis
Travis's Avatar
Supposed to be push in and clock wise.
DIY Volkswagen MKIV Headlight Switch
Looks the same, but I haven't given it a shot yet.
Old 03-16-2013, 04:40 AM
D2k
D2k's Avatar
Could it be that easy to do? Dealer programming sounds like it would be the biggest hassle
Old 03-16-2013, 10:59 AM
CarreraCup03
I have a duraametric, and I think that should work. It has worked for pretty much everything else.
I just tried again to get out the switch per the video. I was able to get it out, but had to push it out from the back. When I get the new switch I will let you guys know if the durametric does the trick.
Old 03-19-2013, 04:21 AM
virkdoc
virkdoc's Avatar
OK so read the earlier post, the guy just changed the switch and the lights worked? No programming?So what about the light sensor?
I am planning to change the rear view mirrow to auto dimming one...that has 5 wires....presuming one for power, one for ground, one for reverse, one for outside Rear view mirrors and one for Headlight sensor??
Old 03-19-2013, 01:07 PM
virkdoc
virkdoc's Avatar
http://www.ebay.com/itm/Auto-CHROME-...39b229&vxp=mtr
this will work?
Old 03-19-2013, 01:55 PM
endless_corners
endless_corners's Avatar
Doesnt look anything like my switch.. You sure you pasted the right link?
Old 03-19-2013, 04:31 PM
virkdoc
virkdoc's Avatar
http://www.ebay.com/itm/03-04-05-06-...ae5c26&vxp=mtr
This is an original Porsche...looks the same??
Old 03-19-2013, 08:38 PM
CarreraCup03
I got this one.
http://www.ecstuning.com/Volkswagen-...--V6/ES257796/
Old 03-19-2013, 09:16 PM
virkdoc
virkdoc's Avatar
Yep so all these look the same....so all we need to do is plug this switch in and auto lights will work?? What about the Light Sensor??
Quick Reply: Auto On Headlight Retrofit? - '06 Cayenne
