Lots of Coils Information -Slight Roughness at low speeds ?
Old 12-05-2009, 10:48 AM
  #76
Slow Guy
Slow Guy's Avatar
Originally Posted by bigbuzuki
Just had all 8 coils changed due to them being cracked @ 105,000 km (2003 Cayenne Turbo)
They installed the new -5 part number coils.
I had symptoms of misfires and sluggish response.
Fuel consumption and power have both improved since the change.
They've jumped from -03 to -05 now?
Old 12-05-2009, 11:38 AM
  #77
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
I hope they changed the plugs as well...cracked coils will usually leave fouled plugs.
Old 12-05-2009, 11:41 AM
  #78
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
-04 coils must be exclusive to the 2007 Cayennes.
Old 12-05-2009, 06:09 PM
  #79
bigbuzuki
bigbuzuki's Avatar
Yep, the new part number for the "pencil coils" is 94860210405.
Old 04-28-2010, 05:26 AM
  #80
Shawn D
Shawn D's Avatar
Default Is it finally happening???
oops wrong thread
moved to coils tsb
Old 10-25-2010, 11:08 AM
  #81
mudman2
Moderator !x4
mudman2's Avatar
Thought I would add these pix to compliment Wingless pictures earlier in this thread.
In order to get the design cover off the passenger side (left side when facing the front) you need to remove the engine stabilizer bar and loosen the airpump so you can lif that out of the way, its still tight but its less destructive.
The stabilizer bar is a straight forward 2 bolt remove
Last tip make sure you have a full set of torx style sockets and on the drivers side, cylinder 1 design cover screw is a bitch unless you remove the airbox, but if you have a small 1/4 drive ratchet you can just get it in.
I will not share the bad photo's until my dealers comments on the bad quality workmanship I found, ugh
The error was P0358, as you can see all 8 were cracked
Old 12-04-2010, 10:50 AM
  #82
georgef
5th Gear
georgef's Avatar
Pelican has an updated part#Product Information: OEM-94860210408 for the coils
Old 12-04-2010, 11:12 AM
  #83
CWhaley
CWhaley's Avatar
Suncoast has them for a complete set at http://www.suncoastparts.com/product...y_Code=955main
Old 12-19-2010, 08:03 PM
  #84
georgef
5th Gear
georgef's Avatar
Thank you for the tips. I replaced coils and plugs today and the 955/s is running nice now. Not at first. I had to drive it a bit. I purchased the parts from Sunset Porsche. clark, jeff porscheparts@sunsetimports.com latest updated coils are $33.93 each
spark plugs are $16.42 each
ALL factory Porsche Parts
all in stock. Dealer cost + 15%
Old 01-01-2011, 09:16 PM
  #85
Fixer
Fixer's Avatar
It is likely a coil pack, u should renew all of them if u can afford to they have been updated. My #1 went at 66k miles ans had the same symptoms it will get much worse if one goes completely. they cost about 50 bucks each very easy to do yourself, did mine in dark with flashlight in mouth and was simple.
Old 01-06-2011, 04:32 PM
  #86
nsapgs
6th Gear
nsapgs's Avatar
Part number is now up to 08 as of today....I just replaced mine in my 04Cs...
Old 01-07-2011, 04:46 PM
  #87
seankrider
seankrider's Avatar
Is anyone replacing them when they're not cracked? What's anticipated lifespan? I think I have 04s and they seem to be fine, but thought I'd reaplace them at 50K for good measure. There's got to be a reason it's been modified several times...
Old 01-07-2011, 04:48 PM
  #88
mudman2
Moderator !x4
mudman2's Avatar
I think a better question is " has anyone seen any coils that were not cracked on removal" they seem to be cracked and still work and then breakdown eventually
Old 01-07-2011, 06:44 PM
  #89
seankrider
seankrider's Avatar
I pulled two right after doing my coolant pipes a month or two back, and they looked good. Engine was clunky because a plug was oily. But the coils looked fine. I think they were replaced 20K back.
Old 03-15-2011, 02:24 PM
  #90
TenaciousT
TenaciousT's Avatar
I have an 04' CS that seems to 'stutter' sometimes when accelerating in 5th or 6th gear. Feels like it's in too high of gear and I will usually downshift with the tip. Mostly notice this when it's warm and been driving a while. No other issues with idle or anything. Could this be coil symptom?
Quick Reply: Lots of Coils Information -Slight Roughness at low speeds ?
