Lots of Coils Information -Slight Roughness at low speeds ?
Old 06-30-2015, 05:00 PM
  #151
Matt55
Matt55's Avatar
Having same problem thanks for all the info
Old 09-01-2015, 11:59 AM
  #152
Sniffer
Sniffer's Avatar
Has anyone replaced coils on the 957s?
I`m curious if its the same process as the 955s which required temporarily relocating the air pumps - I looked briefly last night but couldn't see any air pumps at the back side of the engine banks like the 955 pictures I saw
I`m getting a roughness when idling and hesitation at lower RPMs when accelerating (particularly on inclines) - for those that have had this issue does this sound like coils? (the car is still pretty new to me and I suspect it has had a bad coil/coils since I got it)
I`ve checked and I aint getting any codes to suggest there is an issue but I know from reading this thread that a bad coil/coils won't necessarily give a code, my seat-of-the-pants code reader strongly suggests there is an issue though
So what are the latest coil part numbers? And what are people replacing the originals with? Genuine Porsche (would imagine they're simply Bosch or Beru in a different frock with a bigger price tag) or Bosch/Beru etc?
Old 09-01-2015, 03:20 PM
  #153
Sniffer
Sniffer's Avatar
Forgot to ask - has anyone attempted to electrically test (ohms etc) the coils to verify which is good?
Old 09-14-2015, 06:23 PM
  #154
TomF
TomF's Avatar
I just changed out the coils on my 2008 CTT at 80k miles. Very easy to do. It is not necessary to remove the air pumps on the Turbo. My coils were replaced at 40k miles with a part number ending in 02 and the newest for the turbo ends in 13.
I too suspected the coils were shot and I am glad I changed them out. I changed the plugs at the same time. All of the coils were cracked in at least one place and in the case of the #1 cylinder, that coil was cracked in three places, resulting in a severely carbon-fouled plug.
It is hard to test these as they arc before they completely fail and throw a CEL. I STRONGLY suggest that everyone with coils over 30-40k miles at least inspect them, and replace if necessary.
My CTT runs much smoother and with less unevenness. Best $375 that I have spent on the Cayenne so far. They were $46 each at Sunset in Ore.
Cheers,
TomF
Old 09-20-2015, 01:08 AM
  #155
Sniffer
Sniffer's Avatar
Cheers,
TomF
Thanks for the info
Although the car is a 2008 the engine was replaced less than 10,000 Kilometres ago under CPO due to cylinder scoring
So, in theory the coils & plugs have less than 10,000 Kilometres on them too, what I can't know however is what version is in there if this was a complete engine (which may have the older more problematic variants of the coil packs as I`m guessing it sat somewhere for a while before being used)
So if they're bad theres generally cracking (but not always)? Has anyone tried testing them electrically with a multimeter (Ohms etc)?
Old 02-15-2016, 04:09 PM
  #156
wrinkledpants
wrinkledpants's Avatar
Beru makes the OEM units. Only real way to definitely rule out a coil is to replace it. Functionally, they're difficult, if not impossible to truly test since they can give sporadic performance based on the temperature of the coil itself, plug health, load, and whether you're open or closed loop.
Plugs and coils aren't very expensive - so I'd just replace them all to start with. Any dealer or indy is likely going to charge you a ton of money to troubleshoot it given that there are no codes to lead them in a direction.
Old 03-14-2016, 02:19 AM
  #157
Brad Bedell
Brad Bedell's Avatar
Curious, has anyone tried a set of coils from Beck Arnley? I installed a set a couple of days ago (in an attempt to save $160 from the dealer's $400 price). They run great, but found them BA units to throw DTC's on all 8 coils. Thinking maybe I caused an issue, I checked grounds/wiring/etc and finally swapped a couple of cracked coils in and the DTC went away. Needless to say, I'm out a couple of hours time and going to the Dealer in the morning for parts.
*edit* Picking up factory OEM coils fixed my codes. I can only assume Beck Arnley coils were not quite compatible.
Old 05-02-2016, 05:57 PM
  #158
Glaze88
Glaze88's Avatar
Thanks for all the info guys.
I just made a post about this, so I will look at coils as the issue 1st and foremost.
Anyone know what the best Ignition Coils are to get for the CTT 06?
Old 05-14-2016, 01:04 PM
  #159
John Rose
John Rose's Avatar
Default rough idle
My rough idle comes just as I come to a stop. Its like the Idle is too low then its rights itself after a few seconds.
Old 05-14-2016, 01:31 PM
  #160
Sniffer
Sniffer's Avatar
That *may* be a different issue - bad engine mount or similar?
Old 05-14-2016, 01:33 PM
  #161
Sniffer
Sniffer's Avatar
I ordered a complete set of coils yesterday from Pelican, gonna plug the car in later to see if there are any codes but my seat of the pants tester definitely detects all the symptoms of defective coils that are mentioned here
Old 05-17-2016, 09:36 AM
  #162
morrisdl
morrisdl's Avatar
I have the exact same symptoms on my CTT with 90k, but the only code I get is:
1248 - Basic boost pressure adaption Upper limit value exceeded
Could be unrelated and Ill work on the presumption of a boost leak AND order some plugs and coils.
Old 05-17-2016, 02:10 PM
  #163
Sniffer
Sniffer's Avatar
I find some codes are pretty well meaningless (i.e. the car has recorded a code as the result of a parameter going outside its set limits but in the real world its imperceivable)
I have read that coils can be faulty without any codes being present - in that instance its a calculated guess based on the seat of your pants feel (which is what I`m going off) compared to what others describe about the symptoms of the fault.
Old 08-09-2016, 08:09 PM
  #164
kens911
kens911's Avatar
has anyone used the beru oem replacments? instead of the 50$ a piece OE ones?
Old 08-14-2016, 12:01 AM
  #165
morrisdl
morrisdl's Avatar
new coils and plugs fixed my idle stutter and CEL with random code too. Thanks!!
Quick Reply: Lots of Coils Information -Slight Roughness at low speeds ?
