Auto lights sensor...
Old 05-11-2005, 10:36 AM
1988carrera
1988carrera's Avatar
Default Auto lights sensor...
Can any one tell me where the light sensor is for the auto-on feature?
I am trying to see how to prevent the xenons from turing on during day time for a few seconds, pulling in/out of the garage...I wish they put a 10 second delay to avoid unnecessary on and off.
Old 05-11-2005, 02:12 PM
JARO
JARO's Avatar
turn the light **** to the left so away from AUTO feature. DOne!
Old 05-11-2005, 09:58 PM
1988carrera
Jaro, may be my post is not cklear...I know how to activate the feature. I am not sure where the "light sensor" is that turns the lights on and off!
Old 05-11-2005, 10:09 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
Is it the small plastic sensor on top of the dash, center, right in front of the center speaker, down by the base of the windshield?
Old 05-12-2005, 01:28 PM
Renn 951
Renn 951's Avatar
What difference does it make where the sensor is, do you intend to disable it? If so, why would you even take that approach?
Jaro's point is that if you just turn your switch to the OFF position (instead of AUTO) then the lights won't be turning on when you pull into the garage.
Old 05-12-2005, 01:46 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
Perhaps the point of having 'Automatic Lighting' is so that you DON'T have to reach down and operate a switch.
Old 05-12-2005, 04:35 PM
Renn 951
Renn 951's Avatar
True, and if you disable the sensor then you don't have ANY Automatic Lighting and you have to use the switch every time!
Again, I don't understand the point of the original question on why he wants to know where the sensor is -- what am I missing? And what's wrong with the lights automatically coming on when you go into a dark garage?
Old 05-12-2005, 04:45 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
I believe he is merely trying to avoid cycling his Bi-Xenon's unnecessarily in order to maximize their life.
I know when I open my garage door in the morning (daylight) and start the car, if the switch is in Auto, the BiXenons will come on and then shut off right after I pull out of the garage. The sensitivity/delay is not correct for this situation.
Old 05-12-2005, 05:47 PM
Renn 951
Renn 951's Avatar
So you think he's going to try to design some kind of delay circuitry to wire into the system? That would be an interesting mod; I hope he's got all the Cayenne wiring diagrams to avoid unintended consequences!
So, 1988carrera, what are you up to?
Old 05-13-2005, 12:32 AM
1988carrera
Exactly my point. Finally!!! The life of the xenons is decreased by short burst on /off and that is the reason why they do not come when the "flash" feature is used, the halogens are in use.
Old 05-13-2005, 08:33 AM
mudman2
Moderator !x4
mudman2's Avatar
I think for once retro works here, use the switch
Old 05-13-2005, 01:16 PM
ajauch
ajauch's Avatar
Default DRL?
Another fix to this problem is to have the dealer enable the "Daytime Running Lights" feature. Since the lights are on all the time, there's no issue. The sensor still works and turns on the other lights at dark (instruments, sides, rear) but you don't get the xenon on/off thing. DRL is safer anyway, I can't understand why this isn't the default.
Alex
Old 05-13-2005, 03:09 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
Post
Wasn't there a post a while back asking if US Cayennes could have DRL enabled?
Is it merely a programming change or is there a DRL relay or some other H/W?
Old 05-13-2005, 06:47 PM
ajauch
ajauch's Avatar
Yes, this is just a programming change. I have a US spec 04 CT and they did it for me for free at my last service appt.
Alex
Old 05-13-2005, 09:45 PM
Renn 951
Renn 951's Avatar
Has anyone actually seen real data on the expected life of xenon lights?
Quick Reply: Auto lights sensor...
