How easy is it to change the oil in the Cayenne?
Old 09-28-2010, 12:36 AM
  #61
Munchdog
Munchdog's Avatar
Thanks Vino!
Old 10-12-2010, 12:19 AM
  #62
Munchdog
Munchdog's Avatar
One last q, do you need the oil filter wrench to remove the oil filter housing, or can you do it without?
I see Suncoast carries it, but at $39, seems a bit steep, unless absolutely necessary.
Thanks again!
Old 10-12-2010, 12:48 AM
  #63
Vino
Vino's Avatar
You do not need that filter wrench for $39.95.
Autozone, at least in my neck of the woods had the proper filter wrench and it was only like $7.00. I am not 100% sure of the size since I have 3 of them(all different) stickers are missing stating the part #. It may be the size that fits VW-
http://www.autozone.com/autozone/acc...er=153159_0_0_
Old 10-12-2010, 01:55 AM
  #64
randu
randu's Avatar
The filter wrench I just bought at Autozone was 76mm 14 flutes and cost $5.95 and worked great and was made of metal.
Randy
Old 10-12-2010, 11:09 AM
  #65
Munchdog
Munchdog's Avatar
Excellent, I'll swing by. Thanks guys!
Old 04-10-2017, 11:00 AM
  #66
kino1161
kino1161's Avatar
Anyone have the part number for the oil filter wrench at Auto Zone? I checked for the 76mm but came up with nothing. They did sell a Porsche one online for $24.99 but which one is the $6 - $7 one?
Old 04-10-2017, 01:54 PM
  #67
cobalt
cobalt's Avatar
Received 1,930 Likes on 1,168 Posts
The unit I purchased from them was for a Dodge IIRC. They did not have a specific unit that fit the cayenne or was labeled as such. It is hard to read but it looks like 1267 or A267 and the letters CTA are marked on the inside.
I have one that was supposedly for the cayenne that I paid up for. When I went to use it it didn't have the depth of this one and slipped without removing the housing. It looked like the one in the link above. This works perfectly on my 04 CTT
Old 04-10-2017, 03:26 PM
  #68
kino1161
kino1161's Avatar
Thank you.
Old 04-13-2017, 01:21 PM
  #69
John Rose
John Rose's Avatar
Nobody mentioned resetting the oil change reminder light .
Old 04-13-2017, 01:44 PM
  #70
kino1161
kino1161's Avatar
You're right, John Rose. Do you have anything to add? I know I am due for an oil change but my truck has not reminded me of an oil change. ???
08 GTS
Old 04-13-2017, 02:00 PM
  #71
John Rose
John Rose's Avatar
It seems most folks wold have to go to a dealer unless they just Ignore it and put a sticker in the window . I did my 2003 966 turbo all the time but no light to set.
Old 01-18-2020, 02:40 PM
  #72
levdeb
levdeb's Avatar
Originally Posted by slider172
Make sure to get the right 2 plugs though. I opened the power steering drain plug by mistake.
Only a little drained , but I had to top it off and a liter is $20.
The oil drain plugs are pretty much one in front of the other. The Power steering fluid drain is toward the passenger side about 16".
Just did the same thing, but then realized its not the power steering fluid drain that is 16" away, its the front differential. I know this post is years old, but if someone ends up finding it (like I did yesterday), I just want to make sure you know the plugs are about 3 inches away from each other, and the other plug is the diff. Thanks all!!
Old 01-18-2020, 09:29 PM
  #73
RSbob
RSbob's Avatar
Anyone use an oil extractor? I know you have to remove the front pan to get the filter but if it works. Worked great on my TDi.
Old 01-19-2020, 01:37 AM
  #74
hopsis
hopsis's Avatar
On older V8 Cayennes the oil sump was molded so that oil extractor wouldn't get all oil out. I have a '06 and it has the newer design already. I don't know why they changed it and when. Anyway, with air suspension, this has to be one of the easiest cars to do oil change. No lift needed and plenty of room to roll under the car with a creeper.
Old 01-21-2020, 11:26 AM
  #75
Pillow
Pillow's Avatar
For an S you will want this tool: Oil Filter Wrench – 36mm Metric, Low Profile, CRV Steel – Socket Tool to Remove Cartridge Style Housing Canister Cap
https://www.amazon.com/gp/product/B079P75J43/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B079P75J43/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Quick Reply: How easy is it to change the oil in the Cayenne?
