can't remove upper oil drain plug
Old 04-19-2018, 11:48 AM
stecz
stecz's Avatar
Default can't remove upper oil drain plug
The upper oil drain plug on my Cayenne S won't come loose. Any suggestions? At this point the allen-key hole is stripped. I am able to get the lower drain plug out easily. I assume that over it's life, the upper drain plug hasn't been used. Do I leave it alone and just use the lower drain plug?
My choices at this point are to use my heat gun to heat up the pan, avoiding heating the plug, Maybe go medieval on it with an air chisel and loosen the plug up that way. (I'm ok with replacing the plug after I'm done).
Other ideas?
thanks
John S
2006 Cayenne S
Old 04-19-2018, 02:10 PM
Wisconsin Joe
Wisconsin Joe's Avatar
If you don't drain the other plug, you will leave a fair amount of oil in the pan.
One suggestion I've heard (never used myself) is to take a torx or triple square that's a bit bigger and pound it into the stripped allen hole.
Alternatively, use a dremel or equivalent to cut a slot into the plug and use a big screwdriver.
Heat would be a good idea. Perhaps dry ice chips on the plug itself.
Old 04-19-2018, 02:54 PM
deilenberger
deilenberger's Avatar
Received 1,141 Likes on 758 Posts
And rather obviously - have a new plug and crush ring ready to install.
Old 04-19-2018, 04:56 PM
oldskewel
oldskewel's Avatar
First thing to do, which may not be obvious, is to make sure the 8mm Allen bit is full seated within the drain plug. On my Cayenne, on one of the plugs it seemed to go in fully, but when I tried applying torque, I could tell it was not moving the plug so I stopped. Then I re-set things and lightly hammered (really - think heavy tapping, nothing medieval here) the Allen bit in, and it went in several mm deeper. Then it came out just fine. If you're not sure if it's in all the way, maybe you could measure it on the stuck plug vs. on the removed one - see how deep the Allen bit goes in before it bottoms out.
If that does not work, I'd move up to the next bigger Torx and lightly tap it in there. The torque on these drain plugs is really not much, they're Aluminum so they're soft, which makes the Allen part deformable. But once you get a good grip on it - as with the Torx, there's not much you need to overcome there. It should come on out pretty easily.
Medieval / air chisel no way ever.
Left handed drill bit if all the above fails.
Old 04-19-2018, 05:39 PM
stecz
stecz's Avatar
I do have some freeze spray, that seems like a good first step. Heating up just the pan with a heat gun, might work also. (that way it's not torch heat, but you can get it up to several hundred degrees)
I'll try seating in the allen better and then got for a slightly larger torks.
thanks for the hints
Old 04-19-2018, 06:32 PM
Wisconsin Joe
Originally Posted by oldskewel
...The torque on these drain plugs is really not much...
Unless some ham handed idiot decided that it needed to be as tight as he could get it...
With a long handle ratchet.yy6
Unfortunately, stupid people do stupid things.
Old 04-19-2018, 07:17 PM
nodoors
nodoors's Avatar
That is what I lovingly refer to as 'full ooga!' God help those idiots and keep them away from my stuff!
Old 04-20-2018, 12:33 AM
dpatel710
dpatel710's Avatar
The triple square trick worked for me. My drain plugs were nearly rounded out from the PO/their mechanic. Replacement ones came as 8mm Allen heads and have been much better so far.
Not to thread jack but has anyone tried the magnetic drain plugs for the cayenne? The ones I used on my Audi always leaked so I haven’t gotten any for the pig.
Old 04-20-2018, 02:06 AM
phatz
phatz's Avatar
Perfect timing to get yourself a Mityvac
Leave the plug in place, Mityvac the upper and drain the lower
Old 04-20-2018, 08:58 AM
Petza914
Petza914's Avatar
Received 6,166 Likes on 3,930 Posts
I use LN Engineering's magnetic drain plugs on everything they screw into (997 oil pans, gearboxes, etc) and hoping the cayenne is the same as I have one in the cabinet for my upcoming oil change.
Old 04-20-2018, 12:39 PM
J'sWorld
J'sWorld's Avatar
I am using this. Purchased from oreillys for like $6 each. Never going back to the stockers. They are listed for a Honda. M18x1.5
Old 04-20-2018, 12:45 PM
J'sWorld
J'sWorld's Avatar
You can't Mightyvac the upper.
Old 04-20-2018, 06:26 PM
Wisconsin Joe
What tool fits the hole in it?
It looks square in the pic, but I know better than to trust that.
Old 04-20-2018, 06:35 PM
Petza914
Petza914's Avatar
Looks like it takes a 3/8" or 1/2" drive. What material is it made from? I worry about putting g ate drain plugs into aluminum housings, but that's the safest for the magnet to not break loose and adhere to something ferrous inside the case. Aluminum or brass are better from a softness of the metal perspective, but then you need to make sure the quality of the plug and the adhesive are top notch and that the magnet can't escape. That's why I'm ok paying a little more for the LN one.
Old 04-20-2018, 06:40 PM
oldskewel
oldskewel's Avatar
That looks like the AT drain plug for my Honda Odyssey. If it is the same or similar, the tool is a 3/8" square drive, just like on a ratchet drive. Pretty convenient and easy to remember.
And again, if it's the same as mine, it is steel.
Quick Reply: can't remove upper oil drain plug
